Cat C7 stutter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mission_creek, Aug 3, 2022.
  1. mission_creek
    mission_creek Bobtail Member
    44
    14
    Feb 22, 2021
    Have a 2007 peterbilt 337 dump truck with the cat c7. Starting to develop a bad stutter when under heavy acceleration or going up a hill. No codes or check engine light. HUE pump went bad 2 years ago and was replaced under a recall. When the pump went out it had poor acceleration with an engine light, not really the same issue I have now. Replaced fuel filter, no difference. I figure a fuel loss would would have an engine light. Browsing the Internet I find some posts saying they had the same problem and it turned out to be the turbo wastegate. The turbo on this truck was replaced 3 years ago as well. Anyone have any ideas? Injectors?
  3. SmallPackage
    5,707
    18,254
    Dec 20, 2019
    Marion Texas
    My 3126B would do this every few years and it would always be an injector or two. It would develop a slight intermittent stumble at idle before it would happen as it’s way of giving me a warning of things to come.
    usually when the heui pump was failing it just died because the pump would not stay primed. I could refill the filter. Get it started. Go a mile or two slowly till it would die out again. Repeat, Till I could get somewhere safe.
  4. mission_creek
    44
    14
    Feb 22, 2021
    Wound up taking it to cat. Pump is good but 5 out of 6 injectors are bad. Leaking diesel into the crank causing oil to thin out enough to make the pump fail.
    SmallPackage Thanks this.
