cat code 32 throttle position invalid
Discussion in 'Trucks [ Eighteen Wheelers ]' started by scottroberts, Jun 22, 2011.
  1. scottroberts
    scottroberts Bobtail Member
    5
    will this keep my engine from starting?
  3. scottroberts
    5
    ive tried many other things that i saw on this forum but that is latest code showing when i crank on motor and it doesnt start
  4. Diesel Dave
    9,231
    29,462
    Jan 20, 2010
    Hesperia, Ca.
    I posted the wrong codes. let me try again
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    Are you sure you've got all the codes from the ECM? This code is basically saying the throttle postion sensor is disconnected from the ECM. So you could have more than one wire broken in the harness.
    scottroberts Thanks this.
  6. Diesel Dave
    9,231
    29,462
    Jan 20, 2010
    Hesperia, Ca.
    The research I did display's 32 throttle postion sensor
  7. gwl69
    gwl69 Bobtail Member
    Jun 23, 2011
    lousana alberta
    turn the key off then to the run position three full pedal strokes make shure it's right to floor wait a few seconds turn the key off should recalibrate
  8. scottroberts
    5
    i will check harness again but did find 2 broke wires and fixed them # didnt have the code before i fixed them thanks
  9. scottroberts
    5
    ok i will try to recalibrate thamks
  10. scottroberts
    5
    will run on ether but not diesel , got fuel pressure still invalid throttle position after replaced looking for broken wires in or out of ecm anyone have any suggestions where to look?
