cat codes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cliff_B, Nov 9, 2012.
  1. Cliff_B
    Cliff_B Bobtail Member
    Can anyone help me....I have and 07 International 9400I with a C-15 Cat acert engine...I'm getting a code 128 F07 SID 032 A which does trigger the check engine light but I also get as many as 20 fault codes which don't trigger the check engine light. At times the speedo will peg itself or sometimes the tach will and it will produce fault codes as well as my low oil pressure idiot light will come on but the oil pressure guages will show 60 - 65 lbs of oil pressure. I just had #1 & 2 intake actuators replaced this week. Any help would be great.
  3. truckmaster9400
    truckmaster9400 Bobtail Member
    24
    7
    Nov 13, 2010
    Crawford, Al
    Might be your wiring harness,,,,i have a c13 in a 9400 and mines is doing something similar,i replaced the actuators on #6.the code your getting is #6 not responding.i had mines checked out at yancy cat in savannah,ga.
  4. w900
    w900 Light Load Member
    83
    27
    Mar 25, 2009
    Carlisle,Pa
    Check battery connections and grounds. Make sure key switch is tight
  5. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    I have one that through this code and pretty much would miss at over 1300 rpms in 7th gear and above.. Turns out I had a hole in the air cooler and and acuator on the turbo was stuck. not sure if it was the exact same code but I just remember it was a 128 with some other codes behind it..
  6. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
  7. Diesel Dave
    9,332
    30,118
    Jan 20, 2010
    Hesperia, Ca.
    I have a fault code for my 3406E "2 6". What the purpose for this sensor and if it's bad, how would it effect the engines performance ?
  8. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    According to my code list, 26 is barometric pressure sensor.
    Diesel Dave Thanks this.
