Ive ran a lot of cats and this is my first cummins, When i start the cummins in the cold say 35-40 degrees the oil pressure barely hits 50 at idle now a cat will go to about 80lbs at this temp at idle, is this normal for a 2002-2003 cummins ISX ?
2hellandback
Cat / Cummins oil pressure
Discussion in 'Ask An Owner Operator' started by 2hellandback, Apr 27, 2008.
That would be normal. Some run about 60. But 50 is the norm.
You don't even want to knwo what my big cam runs!. lol, it would send ya running and screaming to the shop for an overhaul if you don't know better
both int's with cummings i've had run 20 PSI at idle and almost 40 PSI when running at 1375 RPM
now that sounds like a big cam, but I know that isn't what you've been driving. That's just worn out company truck that doesn't get it's oil changed enough
MY truck is right there with ya panhandle..
i have 05 379 ISX -
I've never seen a cummings???
