Im working on my NXS Acert, changed all injectors however when I load in the trim files they reset to old ones once the key is turned off and on. They load in fine and stay in until key is turned off. Has anyone seen this or know how I can get them to stay? Thanks for any help.
Cat ECM Loosing Trim Files
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chevyho, Oct 22, 2016.
Never seen that. Are you loading them from cd or websis? Try the other and see if that works.
Have tried both.
Checked that your ECM board button battery is not dead & only getting charge when ignition gives power from truck batteries?
Usually in computers it only stores bios setting but maybe it stores something related to engine maps in your case.Chevyho Thanks this. -
Any update....this is a new one for me.
Yah what a miracle I found a way to get it to take the files after 4 hours of trying everything. If programming #6 I had to install trim file then exchange it with another cyl. Shut key off and on, before resetting screen exhange back to #6 and boom it stays. If any of that makes sense. Just odd.
Odd indeed, but glad you got it done!
Anyone know if its possible to install trim files without the confirmation code? We are missing one.
I don't believe you can....time for a dental mirror and a good light!
Haha i dont understand why number are on the back of the injector on reman units
