2006 freightliner century. St
Having the 20amp fuse keeps blowing replaced 20amp keeps blowing.checked codes using cruise control got 5-5 which i found out means no codes Any suggestions
cat electrical issue
Discussion in 'Ask An Owner Operator' started by C15headache, Mar 11, 2015.
How about telling us which 20 amp fuse (circuit) it is?
The fuse board/block should be labelled with that info.
PS: This thread belongs in the "garage/repair" forum section. -
O ok thanks new to the site. The 20 amp fuse is the one where the batteries are along with the 30amp ecm fuse and a 15amp no label on eaither of them.
If it has the auto/shift trans. one fuse is for ECM other is for trans. power.
Wow thank you that was helpful. Let me check a few things out.i have an apt. With the dealer so hopefully they can fix the problem.
