Time to kill and I can't seem to find the answer : I've got an intermittent "Check Engine" light. The Cat code says "290-7". Anybody know what it means?![]()
Cat Engine Code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sneaquie, May 6, 2011.
Caterpillar Diagnostics Codes-pdf
Looks like 290-7 is #6 Intake Valve actuator not responding... -
Thanks Strider. Any idea what that means, why it's intermittent and how serious it is? Also, I'm not sure it's an ACERT engine. It's a 2006 C15.
It's deff an ACERT and it could be caused by the sensor on-top of the head, pass side, near the front. I don't know what it is called, but mine kept throwing that code as well and changed that sensor and it went away.
Thanks. I'll check it out. Hopefully not an arm and a leg!
its a solenoid on the valvetrain inside the valve cover on cylinder 6 ferthest back sensor these things go bad all the time just changed all mine out a month ago with the new revised american made ones and the jakes actually seem a lot stronger now too
SHC Thanks this.
