cat filter base
Discussion in 'Trucks [ Eighteen Wheelers ]' started by W900KW, Apr 22, 2010.
  1. W900KW
    W900KW Light Load Member
    52
    14
    Jan 18, 2010
    south dakota
    I have looked everywhere and i cannot find the pn# for the cat fuel filter head that flows more? I have read it on some post but cannot find it in search or looking for hours. Any help would be appreciated.
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    a new 120 gph fuel filter head, CAT part #280-2698...
    Dont know a thing about this filter, a number i found on the web, somewhere??? Saved it to a document where i keep Cat notes etc. I believe i asked the forum about this filter head, looking for info on it and i never got anthing on it. So take it accordingly..... :biggrin_25526:
  4. Jas
    Jas Medium Load Member
    That is definately a Cat filter base to take a 2568753 or similar water separator filter but I cant see if its higher flow or not.
  5. Rafferty
    Rafferty Bobtail Member
    26
    6
    Jan 26, 2008
    Iowa
    That is the correct numbers, these two numbers allow a much greater flow over stock. The big Cat at WOT can draw more flow than a FS1000 can deliver.
  6. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    Hello Rafferty: Do you have any more info on the #280-2698 filter head?
  7. Rafferty
    26
    6
    Jan 26, 2008
    Iowa
    A dyno test was ran in Arkanas for a customer with both Fleetguard and CAT fuel filters.
    A KW T800 with a 475/1650 CAT with 3.36 rear end ratio.
    Under a full load, the CAT high effiency fuel filter 256-8753 showed an 11 hp improvement and burned .8 gph fuel less than the Fleetguard. At 1400 rpm-- Wheel HP measured 383 and a fuel rate of 20.0 gph CAT versus 373 HP and 20.8 gph Fleetguard.
    A 550/1850 needs around 98 gph where the Fleetguard is spec'd around 90 gph. It is a decent filter but just doesn't flow enough.
    The combination of the 256-8753 and the 280-2698 filter head will flow 125 gph filling the injectors full and providing the full shot.
  8. speedyc-16
    speedyc-16 Light Load Member
    92
    6
    Sep 6, 2009
    ice box,idaho
    Is that the filter base on motor or on frame???????????
  9. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    On my W900, it is on the frame, just in front of the battery box.
    The 256-8753, and the FS1000 are fuel/water separators.
  10. droy
    828
    159
    Jun 11, 2008
    Iowa, LA
    Someone, I think it was on this forum, had posted some very interesting reading, some time back. There were two memos from Cat, called "Information Release Memo"
    First is titled "Improved Performance Fuel-Water Separator Family"
    IRM/408110142.doc FIL04-09 August 2004
    Second is titled "Parts Comparison Bulletin"
    PCB FIL06-01 March 2006
    Good Info in both!
    First one recommends (among others) Fuel Water Basic Configuration
    Base 195-1068 with 1r0769 (axial seal) FWS or
    Base 177-9778 with 1R0771 (radial seal) FWS (This is listed as new design)
    Listed for the following applications:
    Medium engines: C15-C16 3408-3412
    Also offered with Prime time full flow electric pump, which, if I understand correctly, can be used to prime after filter change, along with aiding flow.
    Second bulletin is a filter comparison done by Cat, against some of the big names out there.
    Hoping someone can bring the two back, as they would fit great in this thread!
    Also along these lines, could someone tell me if this filter group (8H-7204) is a fuel water separator, or simply a filter. It is a permanent screen type of filter, that some guys in my area are running. Comes from Cat with 3/8" NPT inlet and outlet, and fellows bring them to machine shops getting the inlet/outlet opened to 1/2" NPT. It just doesn't seem large enough for a big fuel flow, but some of the trucks it's mounted on are running big hp. Kind of curious as to the original application, if anyone does happen to look it up.
    Thanks
  11. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    Which Fleetguard # was used in this test ?
