Cat filters/Detroit engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RW., Jun 2, 2009.
  1. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    Does anyone know if any Cat filters will work on a 12.7 Detroit? Or someplace on the 'net that will let me cross reference them myself? The #'s I'm using now are- Oil- NAPA #1971, Baldwin # B495;
    Fuel- NAPA # 3120 & 3405, Baldwin # BF1212 & BF5810.
    I've got a friend that can get me a deal on some leftover Cat filters, but I don't if any will work. Thanks....
  3. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    Never seen any Cat filters for apps other than Cat. google Fleetguard filters. you can cross part# but not applications. see if your current # crosses to same that the Cat# crosses to
  4. crazzy448
    crazzy448 Light Load Member
    86
    6
    May 3, 2009
    panhandle wva
    You can also use wix.com the will give you spec on the filters.
    common cat filers are 1R1808, 1R1807 oil / 1R0749, 1R0750, 1R0751 secondary fuel / 175-2949 primary fule witch is a fs1000 fleat gaurd replacement and cat coolant filter is the same as a 4017 wix/ napa filter I know the coolant filter is the same and if you have a screw on filter in the frame the 175-2949 filter should be fit
  5. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    Heres where you will get yourself in trouble. example: 175-2949 and FS1000 fit the same thread size but are not same spec 175-2949 is 10 mic 160 gph for 90 gph head. FS1000 is 10 mic 320 gph for 120 gph head . you could use FS 1000 in place of 175-2949 but not other way around unless a restricted fuel supply is ok with you . my point is just because it fits dosent mean its right.
    DD 60s should always have a 7 mic fuel filter in secondary position or in a single filter set up ( Davco)
    Be very careful with your cross reference. if you find a filter that you believe will work then check the specs with mfg to be certain its correct for your app.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Good advice PaulE...:yes2557:
  7. RW.
    715
    995
    Jan 18, 2009
    west central IL
    Thanks for the help everyone, with the cross-reference info I could find, it doesn't appear that any will work. I've read Cat's brochures before touting how superior their filters are, thought maybe they made filters for other brands too.
  8. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    I use cat oil and sec fuel. fleetguard primary fuel. IMO, fleetguard is as good as you can get( im told fleetguard makes Cat filters but never verified) Fleetguard is owned by Cummins filtration . pretty much the world leader in filters. fleetguard makes these brands, Detroit diesel,Donaldson
    Cat(maybe)Baldwin( im told these are Fleetguard seconds) hard to buy a filter not made by Fleetguard unless its Wix or Napa(also Wix) or Fram(junk)
    Hope someone finds this info useful
    RW. Thanks this.
  9. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    Just my own personal preference, when i had a cummins i used cummins (fleetgard) filters. Currently have a cat and use cat filters.
    Im sure it doesnt make a rats butt difference, just my choice.
  10. Jas
    Jas Medium Load Member
    I agree with you, it cant hurt to use the manufactures filters. Not sure about the other makes but if a cat engine has a failure out of warranty and the owner wants some support from cat for the failure the first thing the Cat rep asks is "does the engine have cat filters on it?" if it doesnt they are a lot less likely to help out with the cost of the repair.
  11. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    i would run what the manufactures says as far as fuel filters, a cat run cat fuel filters, a new style detroit n3 injectors 2004 newer make sure u run the correct fuel filter. if the wrong fuel filter is used they will deny your injector warrenty. n3 injectors have to have a certain micron rating, i can't remember what it is.. but as far as oil filters, fleetguards are probally the best out thier, or cat for a cat engine. a fleetguard will be just fine for any engine
