Cat FLS/FTS settings
Discussion in 'Trucks [ Eighteen Wheelers ]' started by V8Lenny, Apr 8, 2009.
  1. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    What they actually do? FLS power at high rpm, FTS power at low rpm, or what? Higher number more power, lower less? What are the maximum and minimum numbers?
    montana cowboy Thanks this.
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    great question Lenny. I look forward to the answer......... david
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    They both run from -127 to 127........but the numbers don't mean as much as you would think. I just spent a day with two trucks on a dyno trying about 20 different sets of numbers. The difference in power between all of them was only 20 Hp to the tires.
    What their relationship is to each other and the specific flash file is, I can't tell you.
    SAR and montana cowboy Thank this.
  5. Jas
    Jas Medium Load Member
    The numbers dont follow any set order and there are appox 32000 combinations of numbers. Most Cat guys have a set of numbers for each application that works best from trial and error and we are all on the lookout for better ones. Numbers that suit a C15 6NZ dont have the same effect in a 7CZ or NXS etc.
    The purpose is so the factory can compensate for changes the engines on the production line, they can add or reduce fuel so the engine makes as close as possible to it rated horsepower.
    Cat doesn't give much information but the general idea is one number tells the ECM where in the rev range to start adding (or reducing) fuel and the second tells it by how much.
    montana cowboy and NFDDJS Thank this.
  6. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    Thanks for the info, Jas. You Cat gurus throw these different numbers around, but they dont mean anything to me........ david
  7. Jas
    Honestly they dont mean that much to me either, all I know is I have a little black book with lots of engine prefix/horsepower combinations, and lots of FLS and FTS numbers with notes about how each one performs on the road (I unfortunately dont have access to a dyno), so all my measuring is seat of the pants style :)
  8. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
    down here there is a truck wit a c-15 he is 1 of the more talked abt baad trucks , he was recently passed by a signature 600 load 4 load now he is seeking revenge and claims he has a new program 4 the ecm, has anything new come out as this may suggest?
  9. Jas
    Nothing new from Cat as far as I know. There is starting to be a few aftermarket programs floating around, PDI, bully dog, etc, not sure how much improvement any of these give though.
    I think DDS has used a C16 600hp file in a C15 before with some sucess.
    I did try a 600hp file (with 0,0 fuel settings) in a C15, it pulled harder than a 550 file with hot fuel settings but I only went for a short trip and then had to take it out as the engine was still under warranty.
  10. cat from the valley
    469
    32
    Dec 8, 2008
    jamaica
    well i cant mess wit my fuel settings as i have not found the rite person 2 do it as yet
  11. dicky
    dicky Bobtail Member
    31
    8
    Aug 16, 2008
    st.paul , mn.
    FLS-FTS 0/0 are the field re-rate values correct?
