Cat ID dash display programming
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nevs, Mar 8, 2011.
  1. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    Is there a way to reprogram the older Cat ID dash displays? Mine will only display boost to 31.8# even though the analog gauge is reading higher. I didn't know if it could be reset in the unit itself or if it had to be taken to the shop and hooked to a laptop. Any information would be appreciated.
  3. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    You cann't do anything about that. Mine is doing same thing so there is always some difference in reading between the manual gauge and the Cat ID. The Cat ID only reads from the ECM and displays the information the ECM receives.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    the cat id in mine goes up to the boost i am making i geuss you can get it reset?
  5. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    CAT ID in the earlier trucks will only read 31.8 psi and there isn't a way to change it. The ECM will read actual boost pressure, but won't send that information to the CAT ID. In an Acert truck CAT ID/Messenger reads much higher than 31.8 psi.
    Nevs Thanks this.
  6. rafa_207
    rafa_207 Bobtail Member
    18
    12
    Mar 9, 2011
    where can I find the cat Id, the display in mine went out. And what Is the name for it.
  7. e500gvr
    e500gvr Light Load Member
    125
    32
    Aug 21, 2006
    Bloomington,MN
    bigkw Thanks this.
  8. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    a little bit off the subject, but still cat ID. will cat id still work with a PDI program in the ecm?
  9. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    yes CAT ID or CAT Messenger will both work with the PDI tune
  10. haystack
    177
    22
    Feb 12, 2009
    thanks for the info, that will be one less thing i have to worry about when it comes time to reprogram
  11. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    I have done a little experimenting and on 40 pin trucks, 5ek,6ts,1lw......even the ecm only sees 32 lbs....so I think its 40 pins that stop at 31.8....I'll check the next 70 pin when I have one in my shop.
