Looking into buying my own truck soon. Peterbilt 385 or 386 or 378. Something for local and regional runs. Most only have a cummins or cat engine. C13 and from what i read about c13 is to get it rebuilt if it has 500,000 or more miles on it. Also can you do a c13 swap to a c12? Or even a detroit? Any info would be helpful thanks.
Cat or cummins?
Discussion in 'Ask An Owner Operator' started by FjSouth, Dec 4, 2015.
Ford or Chevy debate basically. Out of 10 guys 7 are cat guys and 3 choose cummins. Honestly I think it'll depend on what year truck you're getting. As far as swapping motors from cat to Detroit I believe is a expensive swap that in the end is pointless. Just buy the truck with the motor you want. As far as motor rebuilding the condition of the motor will tell you when to rebuild not the mileage so get oil samples and a dyno. Now for my personal opinion I'm a Cat guy. I have 3406E and I love her. Only had her 6 months but we'll go coast to coast if needed. either way make sure you get a 03 or older to run how you wanna run and you'll make out good on either side of the spectrum (long run or short run)
Dominick253, blairandgretchen, exhausted379 and 1 other person Thank this. -
I was in the same boat, and, for me, it came down to what motor was cheapest to work on/rebuild. I can be happy with any motor, but cost to operate was a big factor. So I was on a quest for a pre-EGR Detroit or Cummins. Didn't want to do a motor swap, so I held out until I found a truck that had what I wanted.
blairandgretchen, Terry270, FjSouth and 1 other person Thank this. -
Same as most on here will tell you, same as above. I like the N14 Cummins. Mostly because this motor is what I have most experience with. I like the 3 individual heads. Fix or replace what is needed. Easier for me personally to work on.
I really couldn't tell you if its cheaper to work on. No egr add-ons. Reliable, blah blah blah.
I had a driver in a cabover with cat motor he said overheated. I had it towed to a cat approved facility in Rockford, IL. told them to remove head and drop pan to see how much damage had occured. Well they dismantled entire motor. Pulled pistons. I scrapped truck and never went to another CAT approved garage.
Good luck.Last edited: Dec 4, 2015
Dominick253 and FjSouth Thank this. -
Yeah i dont believe in egr or acert or def crap. In 15 years as a trucker ive seen all the #### that comes with that crap. Thanks for all the comments!
Anything after '07 is junk.
blairandgretchen and FjSouth Thank this. -
I've had good luck out of both for the most part.
FjSouth Thanks this. -
You will find lovers and haters on both brands, in fact any brand. Most pre '07 motors will do you right if the service and maintenance has been done. Even the best motor will be a dog if it has been neglected. Like others have said get an oil analysis and a dyno to find out if it's worth considering. If you are being told about 'rebuilt' this and 'rebuilt' that, get the paperwork, believe nobody.
Heck even now and days with technology it's better to call Cat or Cummins and give them the serial number to see if a rebuild has occurred. For a starter truck I would just assume it'll need a rebuild and have the money on hand for one so if it does you're ready and if it doesn't then keep your money in the bank waiting for that daywhoopNride, Highway Sailor and FjSouth Thank this.
Good advise TaylorMade407, but most new guys come into this game with no money for the rainy days so are one major breakdown away from losing everything.
Highway Sailor, Big_D409 and TaylorMade407 Thank this.
