Cat piston rings
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dgabel03, Sep 14, 2011.
  1. dgabel03
    dgabel03 Bobtail Member
    25
    Oct 23, 2008
    Fond du Lac, WI
    Does anyone know if CAT offers a severe service or heavy haul piston ring for the C 16, like the one that's available for the C 15? Thanks in advance for any help.
  3. Gasienica
    Gasienica Heavy Load Member
    924
    528
    Sep 7, 2011
    Never knew they had these for c-15, what's the difference between the two? Learned something new today about the c-15.
  4. dgabel03
    25
    Oct 23, 2008
    Fond du Lac, WI
    From what I've read on here, they are made a harder material to withstand higher cyl. temps & higher combustion pressures of severe service use. If you do a search DDS has used these in an engine he put together.
  5. Gasienica
    924
    528
    Sep 7, 2011
    Ok. Thanks for the valuable info. I'll look that up and maybe see if I can find anything out their for a c-16. DDS know anything about them if they have them for c-16? If he doesn't maybe Mr. Haney might know something about these.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Dont remember where i got these from but some notes i saved on Cat stuff(I have a lot of notes saved). Look up the numbers to verify!:biggrin_25514:
    Stock top ring 237-0194
    Heavy Haul top ring 247-6130
    An improved top piston ring has been released for engines that are used in high load applications. The improved top piston ring is made from stronger materials. The stronger materials have a proven robustness in order to withstand fatigue due to high load applications. For only the high load applications that are listed below, replace the 237-0194 Top Piston Ring with the 247-6130 Top Piston Ring on the piston prior to assembly in order to provide increased life. High load applications include coal and logging applications. High load applications also include any application with a Gross Vehicle Weight Rating (GVWR) that is equal to or greater than 63500 kg (140000 lb).
    This is a cylinder pack now offered with the updated ring installed....or you have to buy the ring and install yourself.
    3406E (S/N: 2WS1-UP)
    C-15 (S/N: 6NZ1-UP; 9NZ1-UP)
    An improved cylinder pack has been released for engines that are used in high load applications that are listed above. The improved cylinder pack contains a top piston ring that is made from stronger materials. The stronger materials have a proven robustness in order to withstand fatigue, due to high load applications. For only the high load applications that are listed below, replace the 0R-8915 Cylinder Pack Gp with the 10R-8616 Cylinder Pack Gp, in order to provide increased life. High load applications include coal and logging applications. High load applications also include any application with a Gross Vehicle Weight Rating (GVWR) that is equal to or greater than 63,500 kg (140,000 lb).
    Gasienica Thanks this.
  7. dgabel03
    25
    Oct 23, 2008
    Fond du Lac, WI
    Yeah, that's what I'm looking for. Do you know if they have those for the C 16 as well? I have my pistons ceramic coated if they have this ring available I'd really like to use it.
  8. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    If you use that ring for normal light US trucking you will propably have problems with oil consumption and blowby. It's meant for engines that are used long periods at high cylinder pressures to lower ring wear. Low cylinder pressures can not push those rings with high enough force against liner.
  9. Gasienica
    924
    528
    Sep 7, 2011
    Sent DDS a pm to share his valuable in put on these rings in this thread. Well see what he has to say since he used them in a build.
    dgabel03 Thanks this.
  10. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    I'm using them in my C-15. One gallon top up for 20000 mile oci. I've got around 70000 mi on them now.
    I'm 63 000 kg ( 138 600 lbs ) day in and out.
    07 MXS with a BD.
  11. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    With the statement above I agree with Lenny, unless your building an all out race motor a single turbo C15 or C16 will never see enough cylinder pressure to seat these rings properly, especially if a tuned ACERT still hasn't got the job done in 70k hauling heavy. Just my 2 cents.
