CAT Rebuild or Replace?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RustyBolt, Jul 30, 2015.
  1. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Like anyone who owns their own truck, I'm working on my "Down the Road" plan. Eventually, the C13 in my truck is going to need major work. And, for now, I'm leaning toward replacing the motor with a larger one. These 13s are not known for longevity. Nor are they cheap to rebuild (as with any engine). But with CAT engines, I've heard it can go as high as $30k to rebuild. The kit alone is like $13K. Hard to justify that when the truck is only valued at $20K.
    So, if it were your decision, what would you do? Rebuild? Or replace? And if replacing, what engine would you go with? It's in a 2005 International.
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    For those internationals the cummins have been known to last a long time, I have a few happy friends one with over 1mill miles on original motor which is beyond great. I use to drive a freight shaker with a c13 was not a fan at all. Ran quite and didn't have too many issues but it did end up blowing up when another driver got in it.
  4. fortycalglock
    fortycalglock Road Train Member
    6,151
    6,583
    Jun 25, 2011
    Tourist Town, FL
    It's not going to be cost effective to do anything but find a junkyard engine or replace it and send it to the junkyard.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    why junkyard? Put it on ebay and sell it. I am sure somebody from Mexico or Latin America will buy it.
  6. Cat sdp
    Cat sdp . .
    20,926
    72,652
    Apr 8, 2012
    Orion's Belt
    It's probably not going to be cost effective to change engine brands in that truck either ......
    Sell it and buy another or rebuilt would be my thought...
    Cat has in house financing if they install a kit... Also have warranty
  7. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    We need to rethink our strategies for repairing or rebuilding an older truck. With the ridiculous prices of newer equipment the real cost of maintaining older equipment has to go up as well. In reality an older truck might well be worth putting many thousands of dollars into repairs. A truck worth $8k plus an engine at $20k to me looks way better than a high dollar new or used replacement truck with all the headaches and risks generally associated with a new to me truck.
    For the o/p replacing a 'small' engine with a 'bigger' engine will probably be too much torque for the drive line as it was originally spec'd for a smaller engine.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    My theory on owning an older truck.
    If your good with a wrench, have your own shop with the proper tools then it's a no brainer.Youll be $ ahead owning a truck that's paid for and doing all your own repairs.
    But if your that guy who has to bring his truck to a shop to get a clutch ajusted maybe owning older equipment is not for you .
    Oxbow, 062 and Heavyd Thank this.
  9. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    I appreciate the insight. But it's not a matter of if it's right for me or not. I own it, well, partly. And I learned a valuable lesson after I purchased "this" truck. So, for now, I have to decide what to do when the time comes. And, BTW, I don't have a shop. Or all the proper tools. But I can still do a lot of the work myself when it comes to repairs.
    Thanks again!
  10. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    This is sort of my mentality on the subject. The truck itself is in really good shape. Sure it has it's faults. What truck doesn't? I can't see just throwing it away and jumping into another loan for something that will have the same issues or worse. $8-10K for a used engine that has 500K miles left in her before a rebuild is needed (Not sure what the going rate for a swap around here is.) seems like a more practical way of going.
    Now this is info that makes me rethink changing engines. Not sure what the components of my drive line are speced at. I will do some research and see what I can find. I'm guessing (and only a guess) that the clutch would be an issue. However, not so sure about the rest. I know the rears on mine have identical numbers to a co-workers 9400 with a c15. Other than that, no idea.
  11. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Ain't no way in h e double hockey sticks I am financing a rebuild through CAT. They charge a fortune for their parts. And have the highest labor rates in this area ($115/hr) I can only imagine what kind of interest rate they would charge. But I do appreciate the info.
