CAT scale
Discussion in 'Questions From New Drivers' started by Keizer, Dec 20, 2008.
  1. Keizer
    Keizer Light Load Member
    110
    7
    Sep 27, 2008
    GA
    I dont understand CAT scales at all. if you dont stop at the truckstop you dont have to weigh out right? and if you do stop at the T/A you have to weigh out at the scales? and if you do weigh at the scales and your overweight what happens? please explain... i have no idea on any of this info :mlaugh:
  3. ParkRanger
    ParkRanger Light Load Member
    219
    68
    Aug 4, 2008
    Raleigh, NC
    You don't have to weigh at a CAT scale. They are only to check your weight so that when you go through a DOT scale house you know if you're legal or not.
  4. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    No, you don't have to weigh out at a truck stop. The CAT scales and other scale systems are there for drivers that need to make sure they have the weight of their load properly distributed among the axles. There is a certain amount of weight allowed per axle or set of axles, and if a driver picks up a heavy load, they use the scales (which they have to pay for) at the truck stops to make sure they have the weight properly distributed.
    If you pick up a load that's only 10,000 or 20,000 pounds, you don't really need to scale the load.
    Keizer Thanks this.
  5. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    the truckstop scales are to check and adjust your weight so when you hit the DOT scxales you will be legal
  6. panhandlepat
    3,255
    2,243
    Jan 12, 2007
  7. Lilbit
    16,583
    12,233
    Aug 4, 2008
    What can we say! Great minds and helpful people! You guys made it much more simple than I did!
  8. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    Many shippers do not have scales . CAT scales are a service to truckers and there is no requirement to use them . Trucks are limited to 80,000 lbs. total weight but in most states this is distributed to maximum axle weights of 12,000 lbs. on the steer axle and 34,000 lbs on the drives and trailer axle . A CAT scale will give you readings of each axle . If one axle is over the weight may be shifted by sliding the 5th wheel or sliding the trailer tandems . The weight added when filling fuel tanks also must be considered . You'll be in trouble if you can't get the axle weights legal . States like Illinois have no tolerance . If you are over on an axle at an Illinois scale you don't leave until you are legal .
  9. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    I have been over on the trailer by over 600 lbs and the scale in Illinois north of Springfield gave me a bypass. I could not get the tandams to release, let alone slide.
  10. Lilbit
    16,583
    12,233
    Aug 4, 2008
    Doesn't Cat guarantee their scales to be accurate?
  11. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    Same as Flying J. does. However, you have to pay the fine first, then they are contacted and the process begins.
    In Aurora, CO, I weighed at the J and was legal weights with room to spare. Crossed the scale at Limon, and wow, the weights were not anywhere near the scale ticket, but barely legal.
