Cat trouble codes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by underpsi, Feb 5, 2009.
  1. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Does anybody know of a place online to look up trouble codes for a 3406E?
  3. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    When I brought the truck new I got a laminated page with all the codes on it for the C12-15-16 and the E I will try and find it and post it on here later today.
  4. CaterpillarWrench
    CaterpillarWrench Light Load Member
    188
    49
    Nov 11, 2008
    Wrenching feverishly
    Diagnostic Codes
    Flash Code Code Description of Code
    00 52-11 Air Inlet Shutoff Shutdown
    84-14 Quick Stop Occurrence
    171-03 Ambient Air Temperature voltage high
    171-04 Ambient Air Temperature voltage low
    171-11 Ambient Air Temperature Data Lost
    224-11 Theft Deterrent Active
    224-14 Theft Deterrent Active with Engine Cranking
    246-11 Brake Pedal Switch #1 Fault
    247-11 Brake Pedal Switch #2 Fault
    01 71-00 Idle Shutdown Override
    12 111-02 Coolant Level signal invalid
    111-03 Coolant Level voltage high
    111-04 Coolant Level voltage low
    13 174-03 Fuel Temperature voltage high
    174-04 Fuel Temperature voltage low
    14 121-05 Low/High Retarder current low
    121-06 Low/High Retarder current high
    122-05 Med/High Retarder current low
    122-06 Med/High Retarder current high
    21 41-03 8 Volt Supply voltage high
    41-04 8 Volt Supply voltage low
    232-03 5 Volt Supply voltage high
    232-04 5 Volt Supply voltage low
    24 100-03 Oil Pressure voltage high
    100-04 Oil Pressure voltage low
    25 102-00 Excessive Boost Pressure
    102-03 Boost Pressure voltage high
    102-04 Boost Pressure voltage low
    26 108-03 Barometric Pressure voltage high
    108-04 Barometric Pressure voltage low
    27 110-03 Coolant Temperature voltage high
    110-04 Coolant Temperature voltage low
    28 91-13 Throttle Sensor Calibration
    29 30-08 PTO Throttle signal invalid
    30-13 PTO Throttle out of calibration
    31 84-01 Vehicle Speed loss of signal
    32 91-08 Throttle Position Invalid
    34 64-12 Secondary Engine Speed loss of signal
    190-12 Primary Engine Speed loss of signal
    35 190-00 Engine Overspeed Warning
    36 84-02 Vehicle Speed signal invalid
    84-08 Vehicle Speed signal out of range
    84-10 Vehicle Speed signal rate of change
    38 105-03 Intake Manifold Air Temperature voltage high
    105-04 Intake Manifold Air Temperature voltage low
    41 84-00 Vehicle Overspeed Warning
    42 22-11 Primary to Secondary Engine Speed Signal Calibration
    22-13 Engine Speed Signal Calibration Not Performed
    46 100-01 Low Oil Pressure Warning
    100-11 Very Low Oil Pressure
    47 71-01 Idle Shutdown
    71-14 PTO Shutdown
    51 168-02 ECM Battery Power Intermittent
    55 N/A No Diagnostic Code Detected
    56 253-02 Check Customer or System Parameters
    253-11 Check Transmission Customer Parameters
    58 231-11 J1939 Data Link Fault
    249-11 J1922 Data Link Fault
    59 252-11 Engine Software Incorrect
    61 110-00 High Coolant Temperature Warning
    110-11 Very High Coolant Temperature
    62 111-01 Low Coolant Level Warning
    111-11 Very Low Coolant Level
    64 105-00 High Intake Manifold Air Temperature Warning
    105-11 Very High Intake Manifold Air Temperature
    65 174-00 High Fuel Temperature Warning
    66 54-05 Auxiliary Output #06 current low
    54-06 Auxiliary Output #06 current high
    67 55-05 AuxiliaryOutput #07 current low
    55-06 Auxiliary Output #07 current high
    68 191-07 Transmission Not Responding
    71 43-02 Key Switch Fault
    72 1-11 Cylinder #1 Injector current fault
    2-11 Cylinder #2 Injector current fault
    73 3-11 Cylinder #3 Injector current fault
    4-11 Cylinder #4 Injector current fault
    74 5-11 Cylinder #5 Injector current fault
    6-11 Cylinder #6 Injector current fault
  5. C16KIWI
    575
    142
    Jun 14, 2008
    New Zealand
  6. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    None of the the codes my driver said he was getting is on that list. They were coming up on the cat display he said ever since they have been coming up the truck has been sluggish. codes he gave me were...
    179-02, 175-05, 135-12, 032-000, 192-00
    I got him to try the thing with his cruise switch and hes getting 5 and 5 flashes
  7. CaterpillarWrench
    188
    49
    Nov 11, 2008
  8. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
  9. CaterpillarWrench
    188
    49
    Nov 11, 2008
    I just double checked.The codes for a 5EK are the same as these.
  10. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    They aren't on there though. I believe he also said its says with the codes Diagnostics Unassigned So whats that suppose to mean? No actually meaning to those codes? He says its not running right
  11. C16KIWI
    575
    142
    Jun 14, 2008
    New Zealand
    Hey Cat Wrench,This is completely off topic,but do CAT have lower compression pistons for marine use ?????
