I have a 2004 MBN Peterbilt 379exhd. 3.55 gears 22.5 rubber. 13spd averaging 5.35mpg(with a 500hp 6nz tune) but is getting new injectors. Eats to much fuel. Cat+Longhood= Fuel Hog but i had a 1998 379 in 2009 and it was giving me 8mpg(with roof fairing) with over 2million kms. ran it until 2.5million sold it due to recession. When i bought this truck i knew it wouldnt get the same average as the old one. but id like to improve it. most people do detroit to cat but i wanted to know how much it would cost and what would be really difficult? i have contacts for 12.7's non egrs but if i can find the rare 14L non egr in Ontario i will gladly buy that engine. I know most people would be like leave it i will if i can at least squeeze 6.5 mpg to be profitable. thanks
Caterpillar C15 to Detroit Series 60 Swap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Peterbiltt, Dec 25, 2015.
As far as engine cost that's all over the board. Even when a complete engine is found and purchased you run into several items that just were missed and you still need. As far as in cab wiring your good if you could find a pete engine wiring harness for the Detroit it will make it way easier that trying to make it work. Another option may be from a company such as Mawk industry's who specialize in conversion harnesses. Usually putting a electronic engine in an older truck. Honestly I don't think it would be worth the cost to do the swap. If the cat was junk it might be easier to swallow. You will be money ahead to sell it and buy the truck you want.
blairandgretchen and BoxCarKidd Thank this. -
Just my opinion, but part of your problem could be lack of horsepower. I have a 6nz that was set at 500hp, had a 625 tune put in it and I gained some serious fuel economy. The motor used to work and strain all the time now it just loafs along. Idles better runs smoother. It is my understanding 6nz's are known for fuel economy and durability.
buddy of mine has a 12.7 detroit in his 379 gets about the same mpg as you . a brick only does so well in the wind
dustinbrock and granhawler Thank this. -
Make sure you don't have any leaks in the,cac and exhaust manifold. A small leak in either one can be a couple tenths of mpg.
