Cat's Eye tire inflation monitor
Discussion in 'Ask An Owner Operator' started by Brickman, Feb 15, 2008.
  1. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    $235 EACH axle at KW dealer.
    $270 for 2 axles
    http://cgi.ebay.com/ebaymotors/Cats...021QQitemZ310022753165QQrdZ1QQsspagenameZWDVW
    Or $120 for one axle. I'm going to order 2 of the $120s and save $30 I'll have both axles for slightly more than one axle cost from KW.
    http://cgi.ebay.com/ebaymotors/Cats...021QQitemZ310023226574QQrdZ1QQsspagenameZWDVW
    My trailer runs 19.5'' tires and those that have experience with these smaller tires knows that the small ones like to give a driver problems just because they can. I know drivers that swear by the Cat's Eye and would NEVER be with out them. For this price I'm going to try em out.
  3. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    Oh and BTW if you look closely you'll find his website from the Ebay links. More selections there.
  4. Pete_379X
    Pete_379X Super Chrome
    1,006
    123
    Jul 4, 2007
    Let me know how they work out for ya.
  5. broncrider
    broncrider Road Train Member
    only bad i have heard about them was from the tire guy in missoula....
    seems sometimes the eye isnt set at the right psi and will show over/under inflation
    that and when one tire goes flat the other will try to too
  6. Pete_379X
    1,006
    123
    Jul 4, 2007
    Thats why I've been leary of that "crossfire" system.
  7. Etosha
    Etosha World Citizen
    745
    50
    Aug 19, 2007
    Edmonton, AB
    We have them on our trailers, and they are great. Its so easy to detect underinflation.
  8. Eskimo6804
    Eskimo6804 Heavy Load Member
    816
    3,344
    Jun 13, 2007
    Northeast Alabama
    Hey Brick, have you ever looked at the self-inflation systems? If you like the Cat's eye monitoring system, you would love the self inflaters. We set them at 110 psi inflation level and if tires drop below 105 they get inflated back to 110. There is a light that can either be mounted inside the cab or on the front corner of the trailer that will show you when the system goes into inflate mode(thus showing you you have a tire leaking). This system eliminates the need to manually check pressure and gives you piece of mind. I don't know what it would cost to retro-fit a truck with one of these systems as I spec them as optional equipment on all of my new trucks.
    QuietStorm Thanks this.
  9. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    Some how or another unless your line gets cut that doesn't happen. The internal workings will stop the cross inflation at like 10% loss.
    I definately would order that on a new trailer! But I think unless you were changing axles any way it would be cost prohibitive to do it just because.
    :biggrin_25521:
  10. englewoodcowboy
    englewoodcowboy Light Load Member
    298
    248
    Feb 14, 2008
    Chilhowie, VA
    The set for 120 has blk rubber hoses, the dual set for 270 is with S.S. Braided hoses, the dual set with rubber hoses is 230..... 10 buxis 10 bux...LOL
    Looks like a great item to have, would definately look at getting it when I get my lease....
    been away for 10 years so they are making me go back through with a trainer before I can lease... not complaigning as I could use a refresher and get brought up to speed on the log book changes....
  11. Lucifer
    Lucifer Light Load Member
    73
    14
    Jan 1, 2008
    The Morning Star
    Hey Brickman, I take it you are running a step. I have had good luck with cats eye systems in the past. One good thing about them is you can inflate tires with a standard chuck. The inside tires on a step can be a PIA unless you have the dual chuck with the straight end like a Milton 693
