catwalk dot
Discussion in 'Ask An Owner Operator' started by jtlaredo9566, Dec 13, 2013.
  1. jtlaredo9566
    jtlaredo9566 Bobtail Member
    Mar 13, 2013
    I bought a kenworth t600 , had the dot and passed. it did not have a cat walk. Is the cat walk a dot requirement ,
    NightWind and SafetyMark Thank this.
  3. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Not that I've ever seen.
    jtlaredo9566 and Cetane+ Thank this.
  4. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Nope, not DOT required as far as I know, and had combed thru the regs for this not too far back.
    Opendeckin and jtlaredo9566 Thank this.
  5. Lucar
    Lucar Road Train Member
    1,396
    890
    Aug 22, 2012
    Texas
    Catwalk you say...
  6. jtlaredo9566
    Mar 13, 2013
    yes the metal to step on , i have a flatbed rack , the truck came with a stepper but has no catwalk , just asking if its dot requirement to have one on,
  7. biggare1980
    biggare1980 Medium Load Member
    344
    192
    Apr 29, 2009
    Springfield, Ohio
    My truck dont have one either and I've been inspected without anything being said. Think they are more a convenience than a required item.
    jtlaredo9566 Thanks this.
  8. KW Cajun
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    A catwalk is one of those "not-required" DOT items, but if it IS on your truck, it then can be scrutinized by DOT.
    (ie. If it has even 1 loose mounting bolt a DOT bear on a bad day can write you up for it).
  9. Boka
    Boka Light Load Member
    199
    113
    Nov 6, 2012
    It's not required but for your own sake go to a small fabrication shop and have them make you one out of a diamond plate. Should not be too expensive...
  10. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Many trucks pulling vans dont have them. They are not required, although OSHA and some shippers may have a problem with you stepping on the bare frame.
    SafetyMark Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,527
    13,266
    Jul 6, 2009
    i don't know if i'd use diamond plate. more chance to slip on the snow.
    get that other kind. can't think of the name or design but it's geared for traction so you don't slip on the ice and snow.
    just make sure there's a support in the middle to hold your body weight.
