Cause of uneven wear on all tires?
Discussion in 'Questions From New Drivers' started by Xyrex, Nov 27, 2020.
  1. Xyrex
    Xyrex Bobtail Member
    15
    6
    Nov 27, 2020
    Can misaligned frame cause uneven wear on all my tires?
  3. Dave_in_AZ
    396,954
    Pics of said tires.
  4. Lazer
    Lazer Road Train Member
    1,804
    2,880
    Jan 22, 2017
    There are a number of factors that can cause uneven wear:
    Misaligned axles
    Improper tire inflation
    Excessive load, in excess of tire rating
    Mismatched tires
    etc.
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Over inflate tires will wear out the center of the tread. Under inflation tends to wear out the outside edges of the tires. On the front end an out of alignment tends to wear off one edge or the other. Left with out repair the tire will wear off heavily on the edge only. Drives will cup if not rotated (ie if the were rotating clockwise, switch to other side of the drives).
    Uniform wear doesnt mean a bad thing at wall. It happens with time. At one time people were able to get tires with an A/B/C/D rating. A or B were a firmer rubber while C or D were a softer rubber. Yet manufacturers have given up with that as they have formulated better rubber forr the tires.
  6. Numb
    Numb Crusty Curmudgeon
    4,126
    9,584
    Jan 30, 2012
    Charlotte, N.Carolina
    out of align drives will do it.
  7. Brandt
    Brandt Road Train Member
    4,527
    6,219
    Sep 17, 2012
    They have also found the trucks are being built with axles case not being strong enough. So the drive or trailer axles are flexing when driving down the road. The are building trucks with light weight axle that are like 9.5 mm thick and they need to be 11 mm so they don't flex.
  8. MACK E-6
    49,263
    230,619
    How often does this come down to a retread not being done right?
