CB and an amp. in a freightliner cascadia
Discussion in 'CB Radio Forum' started by Deputy Chief, Nov 7, 2010.
  1. Deputy Chief
    Deputy Chief Light Load Member
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    Has anyone, hooked up a cb with an amp. in a 2010 cascadia using the factory provided antenna mounts on the side of the cab? I was thinking of switching the factory antennas with two wilson 2000. Are the antennas co-phase? Will this work? I have a Galaxy 99v and a 400 watt texas star amp. I would like to use. Can anyone help?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If you have a mount on each side of the truck...Most likely it's already a co-phase set-up...One way to tell is look at the end of the coax that hooks to the back of the radio and see if there are two coax cables hooked together at the connector...If so...."CO-Phased". And, in order to make it work, you will have to use two antenna's...Co-Phase harnesses use RG-59 75 Ohm coax which will only work right, if you use two antenna's at the same time. If you only want to run one antenna, you'll have to re-wire the mount you want to use with 50 ohm coax and run back to the radio...(RG-58, or mini-8, or RG-213 or whatever....)
    The 99 and the 400w TS Amp is just fine...
  4. Deputy Chief
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    Thanks Jesse, I'll give it a shot and let you know how it works out.
  5. k8cpa
    k8cpa Bobtail Member
    38
    7
    Oct 31, 2010
    Lincoln Park, Michigan
    Keep the drive down on that 99 or you'll be putting new finals in that TS. Unless it's the high drive.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Texas Stars can usually handle a 4w DK just fine...One thing you have to watch tho, is they won't handle Volts! 14 to 15v's is about max...Hit 16v with a high dead key and watch the smoke!:biggrin_2555:
    I would set the DK on the 99 at just 2w's, and let it swing....Have the Variable on the Amp turned wide open.
  7. Deputy Chief
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    Ok k8cpa, I'll keep that in mind. Thanks.
  8. k8cpa
    38
    7
    Oct 31, 2010
    No Problem, anytime. :biggrin_25514:
  9. Deputy Chief
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    Well guys, I tried the wilson 2000's. The swr's were all over the place, I guess maybe because the coils weren't above the cab. Do you think I would benifit from a top load, fiberglass antenna like a firestick, were the coil is toward the top of the antenna? Or do you guys have another suggestion, for antennas?
  10. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I don't know about the Cascadia, but the 2 Centurys that I had, the SWR's were terrible with the factory wiring. And they use a few Motorola type plug connectors between where the radio mount connection is and the antenna. So each connection is a possible problem.
    Deputy Chief Thanks this.
  11. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    me personally, I like 1 antenna. I have seen some brackets that mount to the mirror bolts for the cascadias but dont know where to get them. and most I have seen use a 5 or 5.5ft fiberglass ant. with that much power i would get away from using the factory stuff anyway. just my .02
