CB antenna warning driving me up a wall
Discussion in 'CB Radio Forum' started by sprayed150, Nov 13, 2016.
  1. sprayed150
    sprayed150 Light Load Member
    137
    121
    Jun 1, 2015
    Fort Lauderdale Fl
    This summer my company gave me a brand new cascadia, i took my working 29lx from my t600 and ut it in, and the factory internal anteanna sucks, it had no range, so i got tired of it went external a few weeks ago
    Went with a d/s mirror bird perch, clamp bracket, ran a new antenna wire to it, no pinching.
    soon as i did it i got a really high swr and a warning. tried another guys anteanna from his truck and it worked(later realized it was the stud that was fixing that issue)
    last weekend i bought a bigger anteanna and a new stainless steel stud, radio worked fine when i was at the jacksonville ta. swr just under 1.5, clear audio and good signal.
    by the time i got up to gainesville i was getting the warning again, but this time instead of not sending or recieving, i can hear people once in a while, i just get a warning when i key up.
    i had the guy bench test the radio and there was nothing wrong with it
    its a brand new antenna wire
    2 different studs both SS
    2 different antennas(3 foot firestick, 6ft firestick)
    anyone have any ideas? im smashing my head into my window at this point
    handlebar Thanks this.
  3. Neverready
    Neverready Medium Load Member
    405
    330
    Jul 24, 2014
    Pocomoke City, Md.
    You're not alone. Go thru Cascadia antenna solutions maybe one will work for you.
    rabbiporkchop Thanks this.
  4. Ridgeline
    22,310
    115,426
    Check the mount again to see if it became loose.
  5. sprayed150
    137
    121
    Jun 1, 2015
    Fort Lauderdale Fl
    mount is tight
  6. Ridgeline
    22,310
    115,426
    Did you go through any rain?
    I'm trying to figure out what could have changed.
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    New coax doesn't always equal good coax. Wilson seems to be having some quality control issues. Did you check everything with an ohmeter?
    rabbiporkchop and bored silly Thank this.
  8. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    that bird perch deal option is the worst available on a crapcadia a stainless steel mirror bracket is a better option... experiment with different coax length 9-12-15-18 ft. if possible... have a mfj or rig expert check your swrs. don't put much faith in any reading that radio swr meter shows you.
  9. sprayed150
    137
    121
    Jun 1, 2015
    Fort Lauderdale Fl
    I'll look for a different bracket mount. haven't had a shop come out and look because I haven't been past one yet
  10. bored silly
    2,714
    656
    Jul 1, 2016
    go stainless steel from a cb shop most all good ones have them... the trk. stop Wilson aluminum ones are cheap and crack... they say their only good for a 5ft. antenna....big rig cb shop in Phoenix sells the 7ft. firestik it's special built for them by firestik whose home base is outta Phoenix.!!!!!
  11. sprayed150
    137
    121
    Jun 1, 2015
    Fort Lauderdale Fl
    ok. ditched the bird perch screw in and got a 2 post mount, used a known good HD ss stud, and a known good 4ft tunable tip antenna. ch40 shows swr 2.2 same for 01. passes antenna self test (did not do this before) but now fails rf output keying the mic. but engine on is different, shows swr 2.8 on 01, 3.2 on 40 and antenna warning again
