cb echo box
Discussion in 'CB Radio Forum' started by jimmyjoe17, Jan 30, 2014.
  1. jimmyjoe17
    jimmyjoe17 Bobtail Member
    5
    i'm looking for the old cb echo box that had slide on it did not have to utcher a radio on the inside it was plug and play...also if you wanted to hear yourself talk all you had to do was ground one of your external speaker wires and you had talk back no need to go inside of your radio...has anybody know were to get one of these vintage echo boxes or chambers there better than any installed on the inside of your radio please shoot me an email if you know anyone that still sells them
  3. Bashnya
    Bashnya Light Load Member
    103
    100
    Jan 2, 2012
    Kingman, Arizona
    Ah... the old spring-style echos. Worked great until you applied a bit of power. Shielded they were not and would they ever feed back! If you have your heart set on one then start trolling ebay, one is bound to show up sooner or later. Or, a competent tech can make you one from parts of an old guitar reverb pedal - they worked on the same basic principle.
    I understand not wanting to hack up your radio but there are modern alternatives. A quick search on ebay gave me this http://www.ebay.com/sch/Radio-Communication-/1500/i.html?_from=R40&_nkw=echo+boxes.
    Properly installed, tuned and operated the internal ones can sound just as good if not better than the old ones. The reason why most people who have them sound awful is because they crank everything all the way to the right.
    Good luck.
  4. LIL_MAC
    LIL_MAC Bobtail Member
    15
    7
    May 2, 2014
    If you are still looking for echo box REDMANS CB SELLS THEM , CANT SAY IF THEY ARE ANY COUNT THOUGH PRETTY EXPENSIVE .
  5. marmon96
    marmon96 Light Load Member
    98
    57
    Dec 27, 2013
    gardner,ma.
    nothing worse than some yahoo :biggrin_25516:on the radio that has to much echo or reverb
  6. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
  7. RockinChair
    RockinChair Road Train Member
    5,248
    13,612
    Feb 19, 2012
    Lubbock, TX & thereabouts
    I have an Astatic MobileMax, and I love it! It has 2 different echoes. Plug your mic into it, then plug the MobileMax into your radio's mic connector.
    If you get one, be aware that the adjustment knobs are VERY sensitive, and make sure your output isn't too hot so that it doesn't overload the radio's mic circuit.
  8. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I wanted an echo box after I bought my Uniden 980, but ended up buying a GOOD noise-cancelling mic with echo (RF Limited 2018) and could not be happier.
  9. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    But how else are you going to sound cool without it? I mean you spend long hours in the cab, you NEED some self amusement at the expense of others right?:biggrin_25525:
