Hey, so I had the CB up and running. I could hear other people talking. However, if I went to talk then half of the time it would freeze and the top bar would be full, but the bottom would me empty so I couldn't hear anything or talk .I'd have to turn it off and back on and hope that it worked. Sometimes, if have to turn it off 5 or 6 times before it fixed itself. Then, I pulled it out to see if I'd somehow switched the ground. It was fine, but I accidentally touched the neg to the pos and now it won't turn on at all. Does anybody have any idea what's happening?
CB Freezes and now it won't turn on
Discussion in 'CB Radio Forum' started by Johnniemac90, Oct 11, 2018.
If it’s freezing up likely internal. Buy a new one. My stereo was doing that and shop dropped in a new one on the weekend. Too costly to repair electronics. It’s all disposable
Diesel Dave, buddyd157 and Johnniemac90 Thank this. -
It's not what you want to hear, but new one or CB Shop. As far as it not turning on you probably blew a fuse. If not you fried the radio.
Johnniemac90 Thanks this. -
If the fuse is not blown, there's a protection diode inside that is probably toast...shouldn't cost more than $20 to fix the diode at the most...As for the freezing, I have no idea...could just be a solder joint...CB Shop should be able to find it fairly easy, if that's what it is.
What type/brand of cb radio is this?
Most likely the cpu board is toast. It’s not worth buying a new board and getting it replaced unless you can solder, it’s labor intensive. It seems to be common with this radio.
