Hello everyone new member here with just a few questions. All help is very much appreciated even suggestionsI am right here near exit 121 on I-95 in Wilson, NC and thought about seeing if Flying J truck stop knew any technicians. Been in contact with family that are partners in a motor comapny just outside of Charlotte, NC. Their main local CB shop closed down and now they are in search for one too. Long story short haha I have been looking for a reputable CB Shop to work on some personal radios. Just bought a radio when I was in Charlotte this past weekend. I snagged a peaked and tuned Connex SS121 Superstar 121 with a power mic. Honestly no idea what's been done to it or what mods have been done. Just installed it in a late 90's model 4dr Chevy Tahoe and it has a cigarette lighter plug for the power source but plan to switch that over to a direct power lead to the battery and a frame ground. As for antennas I have a Wilson Lil' Wil and a K40 I can use. Both magnetic mounts. Have yet to switch that truck to a solid roof mount at least until I find that just right set up I am going to keep for a bit. Don't plan on putting an amp on it. I do have an amp available but I don't see a need to add one unless someone has a reason I maybe should add one. Just don't want to kill performance by throwing a lot of power to it. The antennas I have I don't believe are really rated to handle much added power. Not to sure on the power specs so I may be completely wrong.
Overall I was just wondering if anyone may know a good shop with some reputable techs that I could rely on to work on, check out, and tune this one and maybe a couple more to come later down the line?
Also would you run a Lil' Wil or a K40 on a superstar 121?
Finally I know the SWR needs to be calibrated and the CB synced with the antenna. Any good reputable places to get that done?
Any help is greatly appreciated on these few questions. I know I'm not quite the daily semi driver but just haven't gotten very much help anywhere else except from family and this seems like a great community.
Thank You,
-Rick "Heater"
CB Help and Shop Near Wilson, NC/I-95 Exit #121
Discussion in 'CB Radio Forum' started by Heater, Mar 25, 2016.
Only one I can think of in your area is 8541 Electronics in Laurinburg North Carolina
Exit 105 Kenly Big Boy's has a cb shop. I was not satisfied with his answers to my questions so walked away. I have seen good reviews and bad reviews of his work so do a bit of research,
The superstar 121 is a single final( 1969 transistor) 10 meter export radio in which one band(probably band D) has been converted to operate on regular 11 meter cb fequencies, the power output should be 1 watt on low and 4 to 5 watts on high with a pep swing to 20 watts which is comparable to a cobra 29 and other single final cb radios. I would use the K40 attenna over the little Wil primarily because it can handle more power( rated at 1000 watts) and is taller which means it will receive and transmit better, and will be a better attenna if you do chose to hook up amplifier. What size amp do you have? The radio barefoot ( without amp) should have a range of 5 to 10 miles , if you plan on talking locally further than that then you may want to consider the amp, just boosting your power to 15 watts carrier and pep swing of 100 watts in most situations will increase your range to 20+ miles.
In addition not necessary to run radio to battery it should only draw about 2.5 amps and the cig lighter or aux power port will be rated somewhere between 15 an 30 amps, however running direct to battery sometimes can help eliminate electrical interference and alternator noise. As far as swr you can buy a swr meter at most truck stops ( they sell Astatic brand) 3 foot jumper coax and do it your self, just follow directions that come with meter or google it.
Looks like that radio has a built in swr meter if you dare trust the reading but it should be in the ball park, and also I earlier said band D would be 11 meter, but it looks like there are only 3 bands low,medium an high so my guess is medium band is 11 meter.
Thank y'all very much for the replies. Some very helpful info in these. I may be traveling to Flying J in Kenly to pick up a Wilson 5000 antenna to see how that does in maybe a week's time. It is a Stinger 277 which I believe RMS'ed to around 175 watts. If I do make it to Flying J I will most likely pick up an external SWR as I know the internal meters can be off. Hopefully if I can get it looked at eventually I will be able to answer if it is 10 or 11 meter. If I do run the power to the battery and the ground to the frame i will be hoping to eliminate ignition, alternator, and other engine noise.
A Big Thank You to Everyone for their Help,
-Rick "Heater" -
I have a Wilson 1000 magnetic on my Tahoe.
Both of my radios talk great on it and receive well.
If you run that Stinger amp have it matched to the radio.
When i set SWR on the Wilson it was easy....Only had to clip about a half inch off of it.
My 40 watt Galaxy runs off the cig plug just fine....I run a 5 amp fuse in the radio and it never blows it.
My 250 watt radio does fine on that same antenna also.
Look online for that antenna....about half price of the truck stops...
The 1000 is all you need....about 99 bucks at the truck stop.
62 bucks online...
http://www.neobits.com/weboost_880_...html?atc=gbp&gclid=CN3kt7qL7ssCFY8bgQodf5gLMwLast edited: Apr 1, 2016
Next exit below flying J is Big Boys, in addition to the cb shop out back they have a few antenna mounts in their own store that the flying J, Petro and others do not carry. You might take a look and see if there is anything to suit your application. Do your research if you decide to try the cb shop.
rabbiporkchop Thanks this. -
Edited post.....The 1000 is what I have...
