CB Issues, receiving poorly.
Discussion in 'CB Radio Forum' started by Nascar_Perry, May 10, 2017.
  1. Nascar_Perry
    Nascar_Perry Bobtail Member
    37
    11
    May 18, 2016
    Brought Over from:
    https://www.thetruckersreport.com/t.../cb-poorly-transmitting-and-receiving.429903/
    Below is the current issue I am facing with my CB.
    OK just an update. Got the bird perch installed, re-hooked everything up, recalibrated the SWR. On a good side the system is now stable, however my transmission and receiving range are only within a truck length of me in either direction. So I'm not getting the range that I used to get which would've been a fair distance down the highway in front of me.
    On calibration, the SWR setting is allowing for channel 40 and one to be fairly close to each other with one being ever so slightly higher on the SWR range, however not significantly much.
    The radio check inside my CB is saying everything is passing a test unlike before
    I am trying to find out what would limit my range. The antenna is a 1000 W antenna. And for those wondering my radio is a cobra 29LXBT. This radio and antenna worked amazing in the last truck I was in however since switching to this truck I have had nothing but problems.
    It is at least working much better and is showing as being grounded.
    Photo of Setup.
    https://www.thetruckersreport.com/truckingindustryforum/attachments/img_1661-jpg.179571/
  3. Ridgeline
    22,266
    114,762
  4. Nascar_Perry
    37
    11
    May 18, 2016
    No, I switched out the coax to a new high quality one.
    I'm fearing that when I was having major problems I may have hurt or damaged the CB not knowing the SWR was in the high 4s
  5. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    I'd get it put on a techs bench you trust ASAP your swrs in the high 4S most likely did damage to that radio.
    Nascar_Perry Thanks this.
  6. Ridgeline
    22,266
    114,762
    You know you need to get someone there with a good antenna analyzer and look at the antenna before you do anything else. This will tell you a lot, then you can see if it is a ground issue or if it is actually the radio, I'm thinking a ground issue.
    delta5 and rabbiporkchop Thank this.
  7. Nascar_Perry
    37
    11
    May 18, 2016
    While I'm never want to rule anything out, I'm highly hoping it's nothing to do with grounding considering I'm using the bird perch which screws right into the body of the truck. Just this has significantly corrected the problem that I originally had.
    I am more fearful that I have already caused some damage to the radio as bored silly also mentioned. This weekend I will know for sure, I am going to put in the company's stock Uniden radio and see what performance is like
  8. rabbiporkchop
    9,677
    6,525
    Feb 9, 2012
    Wapwallopen, Pa
    Just because the bracket is grounded to the door doesn't mean the door is grounded to the frame
    bored silly Thanks this.
  9. CW Spook
    CW Spook Light Load Member
    I'm amazed that cb radios can still be damaged by SWRS that low. Ham radio rigs have had SWR foldback circuitry to avoid such damage for 30-40 years, at least.
    Blaskowitz and bored silly Thank this.
  10. bored silly
    2,714
    656
    Jul 1, 2016
    It's not hard at all especially in a big truck. You'd really be surprised
  11. CW Spook
    I'm not doubting you at all, but just wondering why most CB radios lack the protective circuitry that is standard in ham and commercial radios. Stryker has it, and the shutdown value is actually adjustable in software,
