CB operator gets a violation notice for illegal equipment
Discussion in 'CB Radio Forum' started by Gadfly, Oct 1, 2007.
  1. Gadfly
    Gadfly Medium Load Member
    674
    323
    Aug 18, 2006
    Before the
    Federal Communications Commission
    Washington, D.C. 20554
    In the Matter of )
    Sammy Zeigler ) File No. EB-07-AT-176
    Coosada, Alabama ) NOV No. V20073248010
    NOTICE OF VIOLATION
    Released: September 28, 2007
    By the District Director, Atlanta Office, South Central Region,
    Enforcement Bureau:
    1. This is a Notice of Violation ("Notice") issued pursuant to Section
    1.89 of the Commission's Rules to Sammy Zeigler, operator of a
    Citizen's Band ("CB") radio station in Coosada, Alabama.
    2. On August 29, 2007, agents of the Commission's Atlanta Office of the
    Enforcement Bureau inspected the CB radio station located in your
    residence in Coosada, Alabama. The FCC agents observed the following
    violation(s):
    47 C.F.R. S: 95.409: You must use an FCC certificated CB transmitter at
    your CB station. The agents observed two non-certificated Amateur Radio
    Service transmitters that had been modified to operate on CB frequencies
    and were capable of operating with 90 watts carrier power installed in
    your CB radio station.
    3. Pursuant to Section 308(b) of the Communications Act of 1934, as
    amended,3 and Section 1.89 of the Commission's Rules, you must submit
    a written statement concerning this matter within twenty (20) days of
    release of this Notice. The response must fully explain each
    violation, must contain a statement of the specific action(s) taken to
    correct each violation and preclude recurrence, and should include a
    time line for completion of pending corrective action(s). The response
    must be complete in itself and signed by you. All replies and
    documentation sent in response to this Notice should be marked with
    the File No. and NOV No. specified above, and mailed to the following
    address:
    Atlanta Office
    3575 Koger Blvd, Suite 320
    Duluth, GA 30096
    4. This Notice shall be sent to your address of record.
    5. The Privacy Act of 19744 requires that we advise you that the
    Commission will use all relevant material information before it,
    including any information disclosed in your reply, to determine what,
    if any, enforcement action is required to ensure compliance. Any false
    statement made knowingly and willfully in reply to this Notice is
    punishable by fine or imprisonment under Title 18 of the U.S. Code.5
    FEDERAL COMMUNICATIONS COMMISSION
    Douglas G. Miller
    District Director
    Atlanta District Office
    Enforcement Bureau
    47 C.F.R. S: 1.89.
    Section 95.410 of the Commission's Rules states that CB station
    transmitter output power must not exceed 4 watts carrier power. 47 C.F.R.
    S: 95.410.
    3 47 U.S.C. S: 308(b).
    4 P.L. 93-579, 5 U.S.C. S: 552a(e)(3).
    5 18 U.S.C. S: 1001 et seq.
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Sounds more like a HAM operator got busted for running illegally modified equipment on 11 meter.
    But then again, we may never know since the citation/warning was for illegal operation of a CB Station...which may or may not include a HAM operator with an illegally modified radio.
    Yes I see the term CB Station.... the reference is to 11 meter bandwidth relegated for Citizen usage. aka CB Radio NOT the actual type of radio used by the violator.
  4. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    Yeah, i agree, i thought when i was reading it someone had modified a different type of radio, probably ham, and was operating on Citizens Band. i actually went to recheck the title too see if i read it wrong at first
  5. markthetrucker
    markthetrucker Bobtail Member
    25
    Cheyenne, WY
    WOW that sucks! to be him! he could have been running anything like a ranger or a connex. but when you screw around on the ham side they will report you.Those ham guys don't like it when cbers screw around. But they are starting to crack down seems like. I hope they go to Vegas! and Portland! there are a ton of pumped up stations over there.
  6. BUZZSAW
    BUZZSAW Light Load Member
    176
    15
    Dec 14, 2006
    Seems funny that the ATLANTA FCC would go to ALABAMA to write up a station.......When there are so many violators right under their antennas on channel 20 , 6 , & 11.:biggrin_25521:
  7. dancnoone
    9,922
    3,713
    May 6, 2007
    Excellent point. Atlanta is rampant with CB operators that have huge amounts of power.
    But, to make a point. Rev. Al Sharpton will step in and tell you & the FCC, this is where they are from, and this is what they are accustom to. Therefor, they have commited not actual crime. Leave them alone.
  8. BUZZSAW
    176
    15
    Dec 14, 2006
    THAT IS some THIN ICE there...........
  9. Gadfly
    674
    323
    Aug 18, 2006
    I checked to see if the gentleman had a callsign. None came up on QRZ. It is pretty common to find CBers operating illegal equipment. That is a lot of FCC's own fault due the the lack of proper enforcement in past years. The numbers of hams who violate the rules of their service are FAR fewer than that of CB because they are better regulated. Their locations, addresses and other data is recorded. CBers don't have to provide this infomation on a regular basis like the hams do. Sure, there are a FEW people who violate the rules, but, then, there are more than one kind of violation. There are technical violations such as equipment that malfunctions, accidental operations, and disputes that FCC sometimes gets involved in, and there are intentional rule violations of which the operator likely knows he is doing. Remember: don't think they can't FIND you just because you don't have to give them information or because you are mobile! This is the computer age, folks, and the equipment these FCC fellas have is simply awesome!
    So what is going on NOW? Why is FCC going after people, and why CBers when, a few years ago, somebody practically had to smack FCC's faces to get a "ticket"? Time was, the public had a genuine FEAR of FCC and followed the rules. Then, attitudes changed. People became more willing to test the waters. As the FCC began to retreat due to funding reductions and some mistaken philosophies, CB operators began to expand their operations and their willingness to break the law. Each time they got away with it, the more they expanded their illegal acts. "Freebanding,"
    so-called "extra channels" and more and more power--all combined to make CB less and less useful. The less useful it became, the more the users increased their power, the less useful it became.......and so on. It was treated like an appliance because the people weren't actually qualified, didn't really know what they were doing, and it just got worse and worse! Finally, the "export" radio came along and the outlaws made a mistake! They strayed up into the Amateur bands, 10 Meters being the most frequently violated band. This band IS active, contrary to the "freeband" mentality, and when the licensed operators began to hear the unlicensed people up there, they went ballistic!:biggrin_25516: FCC responded to their pressure and appointed a Special Counsel for Amateur Enforcement whose job it was to clean up the internal ham violations AND go after the CB operators that were filching the bands. He went after the rogue ham operators, and they deserved the attention, btw, removing licenses, fining some, then went after the unlicensed operators who were operating on those frequencies illegally. These people even LAUGHED; after all, FCC hadn't bothered them before, and they weren't worried! Then........:biggrin_25524:
    companies started getting warning letters about their drivers operating on the 10 Meter band. Suddenly, it wasn't funny anymore!
    Then 9/11 happened. All government agencies got more funding--including FCC. Their job is to protect all radio spectrum, and in this time, they discovered just how bad the problem had become! If they didn't act against the illegal operators and the dealers of the illegal radios, they'd find their operations moving ever farther afield. Additionally, the Dallas Field Office, FCC, was tasked with the job of going after the dealers and regular CBers who violate the rules.
    Some CBers still are defiant, denying that FCC will ever come after THEM! But more and more, people are finding out that they CAN get hit with warnings and fines. Imagine the surprise they have when the agent shows up!
    The only 'safe' course is to use a legal CB setup and STAY inside the legal 40 channels. There is NO such thing as a "freeband" and no "extra" channels!
    Gadfly
  10. blownscoot
    blownscoot Bobtail Member
    22
    Apr 13, 2007
    Well I think the FCC should find a cure for there problem and not in our homes.I don`t say that running a radio so strong that it bleeds over to your radio 20 miles away.I think we should keep in mind there are more people listening than you think. Repeating or whistling in the Mic for 20 Min's does get quiet aggravating Well you get the picture Roll on:biggrin_25512:
