CB poorly transmitting and receiving
Discussion in 'Volvo Forum' started by Nascar_Perry, May 3, 2017.
  1. Nascar_Perry
    Nascar_Perry Bobtail Member
    37
    11
    May 18, 2016
    OK I am having a problem with my CB.
    I had to install a new amount, coaxial cable's to bypass a problem with the stock set up. I have attached a picture of my New set up in the hopes that this might assist somebody and tell me what's wrong. Here's my problem,
    The CB transmits and receives only with in a very short distance around me. That said you have to be near me in order for it to work, if you are 4 truck lengths away from me I cannot hear you nor can you hear me. Everything else on the CB is set up properly and the SWR Reading is coming up at 1. It was tuned to be at this level.
    Any help would be appreciated. Don't mind the bend in my antenna in the picture this is due to Highwinds when I took the photo. I have tried adding a ground to the bottom of the antenna over to the screw that is holding the mirror mount in place however this did not do the trick and only raise my SWR To 3 so I immediately scrapped that
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    NO ground there
    ANd bad side for the cable....
    KB3MMX Thanks this.
  4. Nascar_Perry
    37
    11
    May 18, 2016
    Would you recommend I move it to the more larger mirror mount bracket? And what details could you give me for a bad side for the cable
  5. sbaumann14
    sbaumann14 Road Train Member
    1,221
    1,409
    Sep 1, 2010
    Rhinelander, WI
    go into the truck stop, (Pilot, J, TA) and look in the CB section for what is called a bird perch. it will be a 4-5in long rod with a screw on end. you replace one of your mirror mount bracket screws with that, and mount your base to that. should solve all your problems.
    the problem your having is your antennae is not grounded to the vehicle. the bird perch will solve all that
  6. Nascar_Perry
    37
    11
    May 18, 2016
    It's funny you mention that as I just came across what the bird perch is by further researching this problem on Google.
    Thank you for answering where I can find one as luckily I get the pass at flying J every day that I'm on the road.
    For any Canadians who would be looking for a bird perch mounts, skip Husky's, they never even heard of this product. At least the ones in the Toronto area
  7. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Get that perch ... Huge improvement in your mount and grounds...
    rabbiporkchop Thanks this.
  8. Trkr3529
    Trkr3529 Light Load Member
    104
    66
    Feb 14, 2016
    I got mine at durham radio in Oshawa, they're just off of thickson nOrth of the 401
  9. Nascar_Perry
    37
    11
    May 18, 2016
    OK just an update. Got the bird perch installed, re-hooked everything up, recalibrated the SWR. On a good side the system is now stable, however my transmission and receiving range are only within a truck length of me in either direction. So I'm not getting the range that I used to get which would've been a fair distance down the highway in front of me.
    On calibration, the SWR setting is allowing for channel 40 and one to be fairly close to each other with one being ever so slightly higher on the SWR range, however not significantly much.
    The radio check inside my CB is saying everything is passing a test unlike before
    I am trying to find out what would limit my range. The antenna is a 1000 W antenna. And for those wondering my radio is a cobra 29LXBT. This radio and antenna worked amazing in the last truck I was in however since switching to this truck I have had nothing but problems.
    KB3MMX Thanks this.
  10. sbaumann14
    1,221
    1,409
    Sep 1, 2010
    Rhinelander, WI
    post this in the CB section, should get some answers there
  11. KB3MMX
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
