Cb radio advice needed
Discussion in 'Questions From New Drivers' started by Handog, Jan 4, 2014.
  1. Handog
    Handog Light Load Member
    99
    85
    Sep 19, 2013
    Newbie here. I've got one week under my belt pulling a tanker. Upon seeing my first pay check I bought an affordable Cobra 19DX IX. Paid ~ 60.00. So far it sucks. I've heard very little communication on it. Mostly static. The truck was pre wired with power and an Antenna hook up. Is this normal? Do high end models perform better? Better antenna?
    Any tips or advice much appreciated.
  3. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Turn the SQ knob slowly until static stops and turn mic gain up. You should get some responses on a radio check. Also check swr to make sure it isn't above 1 or 1.5
    Handog Thanks this.
  4. rwdfinch50
    rwdfinch50 Medium Load Member
    527
    595
    Nov 6, 2007
    Leesburg, Fl.
    You should be able to hear and talk with that radio, even though it's a basic radio. If all you get is static, it's a bad antenna most likely. Check to make sure the antenna mast isn't broken. you can also buy another antenna at the truck stop for just the CB. that's what most of us do.
    The antenna that comes with most trucks is a co phased antenna that is shared with the stereo. They're not the best thing for a CB.
    Also you need a better radio when you can afford it. Use the one you have now, but be looking for a Cobra 29 at the least, although there's many great radios out there. I found many great deals on radios by just asking if anyone has one for sale when you're in the truck stops. Next time your at the truck stop, give a shout out for one.
  5. Trafficcontrolxl
    Trafficcontrolxl Medium Load Member
    487
    445
    Feb 19, 2009
    Omaha, NE
    Better radio is nice but not necessarily a key to hearing and talking more. Your antena is arguably the most important piece of the equipment. Unfortunately a factory pre run coax and antena are known to have numerous issues including poor ground and inaccurate swr/impedance. For low power operation you do not need to spend big money on expensive antenas, just make sure a decent low cost antena is properly mounted.
    Johnjohn Thanks this.
  6. Flatbedn
    1,307
    784
    Nov 12, 2012
    I have had pretty good luck with my factory 660 antennas but I know the worst factory setup yet was my cascadia. You couldn't transmit or receive with a guy right beside you.
  7. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    agreeed i have a cascadia. factory is HORRIBLE, bouhgt a birdpirch, firstick and crap coax from truck stop. i get about 3 miles out of it. also had radio peacked and tuned
  8. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    Check with your company shop on what is allowed if you get an antenna. My trainer paid someone to set up a strong signal but the company shop took it down because it was against company policy. He wasted a lot of $$$.
    blairandgretchen and Pmracing Thank this.
  9. Powder Joints
    7,687
    7,785
    Sep 25, 2007
    Rosamond, SoCal
    Nothing wrong with the radio. Buy your own antenna and mount, external speaker and a RK56 or Astatic noise canceling mic. A cobra 19 with a good tech can be tuned up to sound as good as any out here. There receiver is very good as well. The mic and the antenna are the main things. I would use a 5' Francis whip on a mirror mount on the left mirror. It will work very well.
  10. RiskyBusiness
    RiskyBusiness Light Load Member
    95
    33
    Dec 28, 2013
    Tyner, NC 27980
    What kind of truck is it? I have had several Freightliner Century's (3 lease and 1 I now own) all came with crap for coax cable installed at manufacturer set up as a co-phase (2 antenna set-up). I ripped all that out put some good coax in then got my SWR's down to a 1 with a Wilson 5000 with a single antenna but put 2 on truck for cosmetics. Static on the CB is very common even with properly set antenna's and tuned radio, you might also want to buy some inline noise suppressors (attach to CB power cord) to help eliminate some of noise coming from the truck itself. Take your radio to a CB shop when you can afford it a get the radio peak & tuned right for maximum performance. Adjust squelch till noise is reduced or eliminated, the RF Gain will reduce how far you can pick up a signal.
    Galaxy 99 10 meter radio
    Astatic Mic
    1000 wt Messenger w/ remote switch and 4 fans
    Wilson 5000 Antenna
    Also a good thing to check, companies are pretty strict on tractor modifications.
    blairandgretchen Thanks this.
  11. kidsdad
    kidsdad Medium Load Member
    327
    298
    Nov 11, 2010
    central illinois
    Read your manual to learn how to calibrate the unit before you start buying stuff. Then, go to a cb shop to find out what you need, spending money on trial and error could end up costing way more than tou need to spend. b
