Cb radio
Discussion in 'CB Radio Forum' started by Taskpimp, Sep 20, 2024.
  1. Taskpimp
    Taskpimp Bobtail Member
    15
    Feb 26, 2024
    Cb bad installation
  3. cuzzin it
    cuzzin it Road Train Member
    3,641
    12,489
    Jan 19, 2008
    Berea, KY
    There are not many wires to mess up. Did you overlook something
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    TMI...
  5. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,651
    Oct 5, 2012
    Earth
    NEI
  6. handlebar
    handlebar Heavy Load Member
    A frequent item that gets missed is not putting the frangabulator shaft in front of the re-dibulation transfer switch. Then, if there's not enough glorp on the stem of the bobblefrump, you'll get sparks across the gap of the recondabell. Did you get a left-handed antenna (if on the driver's side) or a right?
    cuzzin it Thanks this.
  7. Thrasher28
    Thrasher28 Road Train Member
    1,246
    3,549
    Aug 12, 2021
    Bowling Green, KY
    When I had a similar issue, swapping out the luminode on the tarbanator is what sorted it out
    handlebar Thanks this.
  8. Thrasher28
    1,246
    3,549
    Aug 12, 2021
    Bowling Green, KY
    Check the in-line fuse. Pretty easy to blow one if you accidentally touched the wires backwards. If it is blown, most truck stops carry them.
    handlebar, Numb and cuzzin it Thank this.
  9. handlebar
    What Thrasher said. Not all trucks conform to the usual "red=hot, black=ground" convention. If your inline fuse blew immediately upon firing it up, the "reverse-biased" diode protects the radio by blowing upon seeing the leads reversed. Unfortunately, an all too common "fix" is to keep replacing the fuse with larger and larger current ratings, until finally the radio fries to "protect the fuse."
    It's easy enough to check the polarity of your power wires with a digital voltmeter, around $9 at Harbor Freight. And a 2- or 3-amp fuse is easy and cheap enough to keep a couple in stock in your cab for the occasional fuse blown by a power surge.
