CB setup on 2016 prostar help
Discussion in 'CB Radio Forum' started by slw206, Mar 19, 2016.
  1. slw206
    slw206 Bobtail Member
    26
    6
    Dec 16, 2015
    Butler, Pa
    I have a 2016 International Prostar as a company truck which i will have for at least 2 years unless i wreck it. I currently have a Uniden 980ssb radio in stock condition with a RK56 mic. The truck has a 4' fiberglass antenna mounted to the top of the drivers side mirror. The truck also has the high roof cover. This is all tuned to a SWR of 1.59 according to radio. The set up works ok but is far from good so hopefully i can get some help. I want to be able to receive and talk further while still being clear. I am not interested in echo boards or any other crap alot of these idiots run to sound cool but no one can understand them.
    I have sitting at home a cobra 29 LTD classic with a stage 2 peaking from a local CB shop that is no longer in business. The only reason i dont have this installed is cause i like having the weather on my radio. I would be willing to purchase a new Cobra 29 LX and have it modded. The Uniden i have is very limited on what can be done to it. I have been told 18w swing on full modulation so that radio will go back in my pick up.
    I would like to know my best options for a great setup. I can have my cobra 29 LTD modded a little more and run about 40 watts pretty cheap along with improving reception. I can do the same to a new 29 LX but i am into about $200 by the time i buy the radio. I also can run new coax to single antenna, run a dual antenna setup and do mirror arm mounts with RG59 coax, run new grounds to antennas since the ground attaches to mirror arms which mount to plastic, run new power and ground to radio (maybe interior lights will not turn on when i key up), or whatever else. I am unsure about ground planes on this truck.
    I will spend some $$ for the radio and antenna/antennas but i wanna keep the coax and grounding expense to a minimum since i will lose that $$ if they sell my truck or get me a new one by chance.
    I will check back often and hopefully be able to answer any questions. If your opinion is to keep it stock then please keep opinion to yourself. Hopefully someone knows what i need to do or maybe just the radio upgrade is all i need.
  3. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    Read the thread Bearcat 980 tuning( page 2) I use a 980 and it will out talk and receive 100% better than my cobra 20 lx. No significant difference between 18 and 40 pep swing watts but if you want to spend money on new radio and more money to let some hack cb Dr screw it up be my guest, most importantly you should make sure your attenna setup is effecient.
    TheDude1969 Thanks this.
  4. wolverine11
    1,629
    1,234
    Apr 1, 2015
    If you want to spend some money then buy the Stryker 955 which is 15watts swinging 60 watts which is 4 times more than stock 980 or 29 ( 1 s unit increase on receiving station) and this way you have a radio with 2 year warrenty that is designed to perform at those wattage numbers instead of trying to mod a 29 to get somewhat close to that( probably 10 swinging 40 with mosfet final uprade) and pushing the radio past its design limits and voiding any warrenty which means you are sol when radio starts smoking halfway through a keyup.
  5. slw206
    26
    6
    Dec 16, 2015
    Butler, Pa
    Yes, i am gonna allow some CB hack screw with my radio. They just happen to be one of the top 5 shops in the country rated by truckers so i feel confident in their ability. I am just lucky they are close to where i live. Also i am not doing a over modulation swing mod. I will be running a small amp. I had stated that what my current antenna setup is. Thanks for giving no real advise also.
  6. slw206
    26
    6
    Dec 16, 2015
    Butler, Pa
    I had considered buying an amateur radio since i do have a current general class radio license. If am gonna be illegal may as well do it right. Kinda easy to spot if anyone ever investigated. Not sure i care about warranties since even opening the radio voids it.
  7. wolverine11
    1,629
    1,234
    Apr 1, 2015
    I dont believe the exports come with weather band which is a feature you are wanting, but I just think it makes more sense to buy a radio designed for high output instead of spending money to mod one that is only designed for 4watts. If your not wanting echo you can buy a Galaxy 29hp for about $170.00 + conversion and tune and have a radio that does 10watts swinging 40 for about $ 200.00. As far as any agency looking for 10meter radios being used on 11 meter, in 20 years Ive never seen it take place the only ones looking for high dollar radios are thiefs.
  8. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Sorry I wasnt able to give you great advice but if you are set on modifying a cobra 29 the one I would suggest is the mosfet 520 upgrade but if you plan on running a small amp ( which you didnt mention in original post) the why are you planning on modding a radio, jusy have deadkey matched to amp and your good to go, good luck I sincerly mean that.
  9. wolverine11
    1,629
    1,234
    Apr 1, 2015
    That Bearcat 980 is a good radio to hookup with a small low drive amp, I ran mine into a 450 mosfet low drive in my pickup for a while and it worked great, input requirement for amp is 1 to 5 watts and no more than 15 watt swing with amp on carrier was 75 watts swing was 300+ .
  10. volvo244t
    volvo244t Road Train Member
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    You are not going to get 40 watts out of a Cobra 29. Mosfet or not. Anyone who tells you it is possible is at best delusional and at worst a con man. The amount of experience they claim matters not.
    Remember, a wattmeter is a simple device. It cannot distinguish between actual on-frequency signal and harmonics caused by distortion due to improper modification (i.e. spread coils, clipped or improperly set limiter, and other crap mods like npc mods and swing kits) and harmonics will cause it to read higher power than is actually being transmitted on-frequency. Even the venerable Bird meters are subject to this phenomenon.
    A Cobra 29 that "swings 40 watts" will be outperformed in transmissions by a stock 29. You will be loud up close, but a couple miles down the road you'll fade out, meanwhile I'll hear the people talking on stock radios 10 miles down the road. Compare the two on a spectrum analyzer (a piece of equipment the shop I believe you're talking about does not have, at least I haven't seen one in the many times I've been there) and you will easily understand why with the knowledge that every harmonic spur that is present takes power away from the fundamental frequency - the only one that will reach the receiving radio.
  11. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Watch out volvo244t you are going to be accused of giving no real advice.
    darthanubis and TheDude1969 Thank this.
