Cb wire
Discussion in 'Freightliner Forum' started by Charger_ff, Aug 9, 2017.
  1. Charger_ff
    Charger_ff Bobtail Member
    6
    im in a 2012 cascadia. I found where the cb gets mounted and I'm wonder if this is the cb wording for the truck . I tested the voltage and it reads 10-11 volts. It has a plastic connected with 2 wires. One black n another goldish. Pic above or below
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,897
    May 25, 2017
    under a shade tree
    my shaker DOES NOT have 2 wires in a connector like that. i have a red and a black. i'd not trust that you have.
    somewhere in the upper console, there has got to be a red/black wire set up, maybe tucked far into the forward most near the windshield?
    if not, get a cigarette lighter adapter and plug it into that, like i do now in my current truck. reason being, i may have to empty out my truck and i want quick work, not struggle with things.
  4. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Nope. That is correct. It is the wiring for the CB...or at least intended for it.
    BTW...it is not a goldish wire--it is TAN. And if you look really closely, it should be TAN with a white stripe.
    At any rate, that pigtail is indeed intended for the CB wiring. It is part of the overhead connector. The black wire is obviously the ground wire as well.
  5. Charger_ff
    6
    Thanks. Do they have an adaptor for the connector? Or do I have to hard wire into the wires
  6. TOMBOYga
    TOMBOYga Bobtail Member
    So I hook my black wire to black wire. An my red to the tan an white wire
