CDL physical and hearing aids
Discussion in 'Questions From New Drivers' started by Vaughn58, Nov 17, 2014.
  1. Vaughn58
    Vaughn58 Bobtail Member
    Parker, Pa
    I wear hearing aids. My left one being the worst one with about half of normal hearing due to an ear infection a couple years ago. Should I try taking physical without them hoping I can squeak by hoping I can pass to keep them off my medical card. If I can't pass without them then tell DR I have them or be up front with DR to see if will try without first.
  3. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    I went to an E.N.T. (ear , nose, throat) doctor, and got a hearing test from them, and took it to my DOT physical. They accepted it
  4. RGRTim
    RGRTim Light Load Member
    168
    119
    Aug 28, 2013
    Greenville, TX
    I took my physical with mine in to avoid any problems. Does it mean that they are listed on my med card and my DL? Yes. Is that an issue? No. I wear them all the time anyway so what difference does it make. Wear the hearing aids, take the test, pass the test then get on down the road.
    Tonythetruckerdude and heyns57 Thank this.
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    They don't do a hearing test. If you can carry on a conversation with the doctor without them you will pass.
  6. RGRTim
    168
    119
    Aug 28, 2013
    Greenville, TX
    Maybe it was because I was wearing my hearing aids when I took the physical but they did do a hearing test.
  7. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Ya, I'm sure that was the case. I've never been tested. The fact that we have a conversation is enough I'm guessing.
  8. Scott101
    Scott101 Medium Load Member
    607
    407
    Nov 30, 2008
    NorCal
    There is suppose to be a "forced whisper" test. The examiner stands like 5 feet away and does a relatively loud whisper in each ear.
    I'm pretty sure the guidelines are listed right on the long form.
    heyns57 Thanks this.
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Ya but nobody does it
  10. Scott101
    607
    407
    Nov 30, 2008
    NorCal
    Tonythetruckerdude Thanks this.
  11. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,906
    49,632
    Dec 8, 2012
    hunting...../ retired
    Not trying to argue here but , I've been tested with the forced whisper every single time I've taken a DOT physical....over a period of 30 + years that's alot of physicals too.
    heyns57 and Scott101 Thank this.
