CDL question.
Discussion in 'Prime' started by mdmedicgod, Dec 28, 2012.
  1. mdmedicgod
    mdmedicgod Light Load Member
    144
    54
    Nov 29, 2012
    salisbury, MD
    I currently hold a MD Class B CDL with airbrake and Tank endorsements. If take the permit test in SpringMO will I only have to take the combination written exam?
    Patrick
  3. MsJamie
    MsJamie Road Train Member
    I'm in the same boat as you; class B with everything except hazmat (had it before; doesn't transfer) and doubles/triples. You should only have to take the combination test (and road test); you should be given credit for everything else.
  4. cl8936
    cl8936 Light Load Member
    217
    92
    Apr 17, 2009
    St. Louis, MO
    Not sure if this is still relevant, but because you have an out of state license that is not class A, I would plan on retaking all tests (air brake, combination, gen. knowledge) in Missouri.
    silenteagle and 123456 Thank this.
  5. trainer007
    trainer007 Bobtail Member
    28
    22
    Jul 25, 2012
    Everywhere, USA
    That is true. You will have to go through all of the training again for combination. It is a different beast altogether. We will help you get through it as quickly as possible though. You can learn a lot from our instructors.
    Good luck!
