CDL Requirement
Discussion in 'Questions From New Drivers' started by Matt Smith, Oct 4, 2015.
  1. Matt Smith
    Matt Smith Bobtail Member
    4
    Hi, I am looking at getting a dually one ton pickup truck to carry a trailer I have that has two 7,000 pound axles (14,000 GVWR). If the dually has a GVWR of 14,000, wouldn't that put me in CDL territory? I'm confused on this subject.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,518
    9,826
    Mar 30, 2014
  4. Matt Smith
    4
  5. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
  6. Matt Smith
    4
    Great. So it seems like even if my truck is 14,000 GVWR and my trailer is 14,000 GVWR, I'm okay so long as the equipment I'm hauling doesn't weigh more than 10,000lbs.
  7. Matt Smith
    4
    I should have put a question mark at the end of that question...So it seems like even if my truck is 14,000 GVWR and my trailer is 14,000 GVWR, I'm okay so long as the equipment I'm hauling doesn't weigh more than 10,000lbs?
  8. Bean Jr.
    5,518
    9,826
    Mar 30, 2014
    I'm sorry the link didn't work for you. Ive copied the page:
    In 1990 the Federal Government regulated that all commercial drivers in our country will need a CDL when the vehicle has a GVWR
    (gross vehicle weight rating) of 26,001 lbs. or more empty or loaded, air brakes or not! This requires a Class "B" license.
    If the trailer is rated over 10,001 lbs. or more empty or loaded, air brakes or not & hooked to a truck weather the truck is CDL or not buttogether when the GVCWR (gross vehicle combination weight rating) is over 26,001 lbs. you need a Class "A" CDL.
    Example 1
    You have a truck that is rated for 17,500 lbs. and hook it to a trailer that is rated for 12,000 lbs. Do you need a CDL?
    Yes, you need a Class "A" because together they are over 26,001 lbs.
    Example 2
    You have the same truck that is rated for 17,500 lbs. and hook it to a trailer that is rated for 10,000 lbs. Do you need a CDL?
    No, even though they are a combination weight over 26,001 lbs. the trailer did notexceed the rating of 10,001 or more lbs.
    Example 3
    You have a large pick-up truck hooked to a beaver trailer rated at 20,000 lbs. Between the pick-up and the trailer you will exceed 26,001 lbs. you will need a Class "A" with an air brake restriction.
    THE KEY
    Is always the trailer. Focus on the trailer's GVWR. If the trailer is over 10,001 lbs. and hooked to any vehicle under 26,000 lbs. it will be a Class "A" CDL if the combined weight puts them over 26,001 lbs.
    If you have a truck that is 26,000 lbs. and hook it to trailer that is exactly 10,000 lbs. rated....do you need a CDL? NO!!
    Why? Because neither of the vehicles exceed the "1" lb. even though they are over the 26,000!!
  9. Bean Jr.
    5,518
    9,826
    Mar 30, 2014
    I hope that was clear. It seems that if the gvwr of the trailer is over 10,001, but the cgvwr is under 26,001, then it is not cdl.
  10. austinmike
    109,907
    Beaver trailer , l o l
  11. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    No. Your trailer can be completely empty and you would need a CDL. They go off the manufacturers GVWR. 100% without a doubt with a 14k GVWR truck and 14k GVWR trailer you need a class a CDL. Doesn't matter what you weigh it matters what you are rated to weigh.
    Bean Jr. and 12 ga Thank this.
