CDL requirements
Discussion in 'Questions To Truckers From The General Public' started by cdwood388, Apr 6, 2010.
  1. cdwood388
    cdwood388 Bobtail Member
    Farmington NM
    I do not have a cdl so take that into consideration. I am looking at buying a freightliner fl70 that has a gvw of 33,000 lbs. It has a box on it now and I will be removing that once I get it home to put a flatbed to haul my 4 wheelers and my 4x4 and tow my camper behind it. That being said since it is for persoanl and recreation use only can I drive it without a cdl, I will in no way make money with it at anytime. It is in Indiana and I will be driving it to New Mexico, is there any way to get around this? Any opinions or suggestions are valued.
  3. truckerdaddy24
    truckerdaddy24 Road Train Member
    1,364
    447
    Jan 24, 2010
    Avondale Az.
    Hey, I'm just a rookie but if you are using it for personal use then put on both sides of the vehicle that it is used privately and that it is not for hire or not used for commercial use, I hope this helps. I'm sure others will address this just give them a few minutes. Take Care. TD.
  4. Diesel Dave
    9,280
    29,738
    Jan 20, 2010
    Hesperia, Ca.
    Yes, your going to need a CDL. Even though its for personal use. Its cause of the size and air brakes. Think about it, you can't drive a motorcycle with a regular class c license.:biggrin_2556:
  5. jwillard88415
    jwillard88415 Bobtail Member
    22
    12
    Mar 11, 2008
    New Mexico
    That's true read your drivers license. A class C license allows you to drive any vehicle with a GRVW under 26,001 pounds.
  6. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    At least you don't have to go to a school! I think you need the CDL B. Just study the book take and pass all the tests in the book at the end of each chapter have the truck registered inspected and the insurance on it and use it for your driving test and you're good to go.
  7. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    you do not need a cdl. this is PERSONAL USE. In some states you will need an air brake endorsement, but i have thoroughly researched this. If it's for personal use, its for personal use.
    There are motorhomes that weigh more than 26,000lb and have airbrakes. Driven by 80 year olds with no CDL. That's just fine, how come?
    You people who say he needs a CDL need to check the FIRST PAGE in the cdl manual! It tells who needs a CDL!
    And if you think he needs a CDL, why exactly do you think he doesnt need IFTA, and an MC number? Anything that needs a CDL would need an operating authority, blah blah blah blah...all that crap.
    however, the words "NOT FOR HIRE" will not be worth the space. That does not mean its non commercial. I would put lettering on it, "RECREATIONAL VEHICLE". However, some cops will still screw with you.
    But a CDL could be useful for job oppurtunities and you can use the truck to get a class B...
    This post is about as ill-informed as it gets. A drivers license is not a class C license. A class C license is a type of CDL. And besides that, my license doesnt say anything about what it's for. It just has a bunch of letters on it!
  8. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Some states require you to acquire a "Non-Commercial" Class 'A'....
    Cali does for say pulling a Fifth-Wheel Trailer over IIRC 13,000....Even with a pick-up.....
    kickin chicken Thanks this.
  9. Jimbo60
    Jimbo60 Medium Load Member
    518
    434
    Nov 25, 2009
    High desert CA
    That's all verbaitim from the CDL manual. As far as RVs there are several non-commercial options including class A which covers 5th wheel trailers weighing over 15k not used for hire.
    To the OP..... this stuff gets convoluted so please save yourself the headaches and talk to your state DMV for the definative answers.
    ................... Jim
    otherhalftw Thanks this.
  10. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Evidently, not quite thorough enough!
    Most every state is different, especially when it comes to weight, and how the rig is outfitted, and the intended use of the vehicle. OP says the rig has a box on it now and the weight is 33k...but how will the weight change after the flat bed is put on and the box removed...this might change the licensing and the registration dramatically.
    To the OP...after you finish getting the rig set up the way you want it...with every trip you use it on...establish your travel route and check with each state you will be traveling through on their requirements for the rig and for your license...with some you will need a permit (one time use fee) so it could get awkward and/or costly not to do your homework.
  11. TIMEWEASEL
    TIMEWEASEL Light Load Member
    128
    59
    Dec 23, 2008
    CLEVELAND, GA
    Commercial motor vehicles are defined as:
    - vehicles having a gross combination weight rating of more than 26,000 pounds. This includes a towed unit with a gross vehicle weight rating of more than 10,000 pounds
    - vehicles having a gross vehicle weight rating of more than 26,000 pounds
    - vehicles that are designed to transport 16 or more passengers including the driver
    - vehicles of any size that are used to transport hazardous materials. Vehicles transporting hazardous materials must have a placard as required by law.
    Examples of commercial vehicles include trucks, semi-trucks, vans, coaches, buses, taxi cabs, box trucks and trailers.
    This is off of the ops state's website
    mvd.newmexico.gov
    Class B sounds like a good and safe choice to me. Plus the extra knowledge you will learn just from studying the book can't be a bad thing either. Just my .02
    Thanks and be safe!
