Center dash lights shut off,...Help
Discussion in 'Experienced Truckers' Advice' started by BZQwEnB, Apr 10, 2018.
  1. BZQwEnB
    BZQwEnB Bobtail Member
    4
    Apr 10, 2018
    2014 International Prostar,...
    The center dash lights shut off,...I've tried skimming through fuses but most are tough to figure out what they're for. I looked up most on the internet but still can't figure this out. Maybe someone can help?
    And the AC just quit working. I've pulled the fuse to reset it while we were running down the road and it cooled a little but not back to full AC,...
    I could use any helpful input, thank you
  3. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Go to rawze.com and get the help you need
    BZQwEnB Thanks this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,712
    18,510
    Nov 1, 2010
    Burnsville, MN
    Many of those ProStars had wiring harness issues. Maybe you are one of the unlucky ones, as it is an expensive fix.
  5. BZQwEnB
    4
    Apr 10, 2018
    Great. I hope not. But I'll keep checking to see if anyone might know how to fix this,... thank you
  6. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Did you try turning it off and then turning it back on?
    ChaoSS Thanks this.
  7. BZQwEnB
    4
    Apr 10, 2018
    I've turned the truck on and off maybe 100 times since I've posted this and it hasn't changed anything.
    Someone told me to take a few of the fuses out for a minute then put them back in but that didn't do anything.
    I asked a shop and they said they'd take a look at it for $100,...
    The trucks running great so I think I'll hold off on the dash lights to see if anyone might know what it is.
  8. Hoofbeats
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Hang a chem stick by your gauges if you need to read them at night.
  9. BZQwEnB
    4
    Apr 10, 2018
    We got it fixed! It was a fuse that we were over looking
    Moosetek13 Thanks this.
  10. Pattyb
    Pattyb Bobtail Member
    I have the same issue what fuse was it?
