been to 3 shops in last 5 months getting steer tires balanced and rotated
2 3 axle alignments and still eating up the passenger steer tire
everyone says they see nothing wrong...........grr
other then I am out of balance
One big a.. pothole in Mich started this mess
Kenworth Speedco and our own shop have no answer
can thiose centramatic wheel balancers help me
when i get tires balanced and rotated everything is smooth for a few weeks
centramatic balancers
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cranky Yankee, Jan 19, 2013.
Page 1 of 6
PM Sent.
Something isn't right. Someone needs to really look at it for you.
The shop I sent you also does truck frame stretching. If Mike or Brad can't figure that out for you, something isn't wrong. -
bump...........bump
Centramatics might help if it really is a balance problem. You've also rotated sides, narrowing it down to an issue only on the right. And you mention that it started with a major pothole strike. All things point to something loose, bent, or broken on the right side.
That said, I've had a run of trouble with Yokohama RY617 steers self destructing after about 50k miles in a similar fashion as you describe. Those were balanced when mounted and have been equipped with centramatics as well for no benefit. However, the problem existed on both sides, and on on two separate but similar trucks (04 and 05 FL Century). Not enough miles on the one that got Firestone replacements to confirm a tire issue, the other truck is getting dumped in a trade so I'll never know on the Yoko warranty tires. It's felt like they're starting to do the same thing, but I just might be too sensitive to it. No visible wear defects yet. -
did your yoko start wearing diagonal lines across the face?RedForeman Thanks this. -
No. They started cupping on the edges, both sides of the tire. A guy I spoke to at the shop in KC I used to inframe my 04 had just come from a 100+ fleet that had big problems with Yoko steers. They claimed some sort of molding defect, indicated by some missing sipes in the edge tread. I didn't see that on my tires. Add to that, I've had some weird wear on inside drives (TY577, all 8 mounted at once, with cats eyes inflated to 90 psi per their own load chart). The trailer tires have been adequate, but definitely no value. The Michelin XT-1 recaps I've been replacing them with over time have lasted 2x longer for 1/3 the money.
I think Yokohamas just suck. So those were the last ones I'll ever buy. -
To add: on the drives, I've spotted a few trucks with the same ones at shops and truckstops all wearing just as badly as mine.
Try running more psi in the tires. Steers and drives.
Have you been traveling threw a lot of side winds making you counter steer to stay straight TransAm Pete? -
Before i have the same problem,yokohama 617(90k),bridgestone 280(107k),now with michelin(140k)and looks and run like new,for me only michelin on my steertire with centramatics
flood Thanks this.
Page 1 of 6
