Anyone have these on-board wheel balancers? I am considering them for my steer axle. Good, Bad ? I need some input before purchasing them.
Thanks,
Centramatic Wheel Balancers?????
Discussion in 'Ask An Owner Operator' started by whoopNride, Jan 16, 2008.
Page 1 of 3
i know i guy who has them all the way around, they work great
saves tire life by a noticeable amount -
they do work but just a point to consider. The rear ones, at least the ones I had mount between the tires and I found out the hard way that road debris can get thrown up and puncture them. I'm sure the odds are they won't but mine did. then again this was many moons ago
To answer the original posters question...In our 11 truck fleet, we average 425,000 miles on drive tires(changed at 4/32 tread remaining) and 185,000 on steers(changed at 5-6/32). We only run Michelin tires(have a couple trucks running X-1's that I am testing), and we also inflate all tires to 110 psi.
The first cycle of tires after installing the centramatics showed a tread life improvement of 26% better than we were getting without the centramatics.
Hope these figures help.Terry270, goose19726 and 1989 Pete Thank this. -
If it wern't for bad luck I'd have none.
How are the x-1's coming along? You have any data for them yet? -
let me know if you want to unload a set of the 14" wheels. oh wait, my truck has stud piloted wheels, can those be converted?
I'll be honest; My mechanical knowledge is very limited. My forte is the business aspects of trucking. Management(all aspects), sales, and "bean-counting" are the things I excel at. -
stud piloted vs hub piloted. The old trucks the wheels are alligned by the studs and not the hub. Stud piloted have a dual lug nut. You put one rim on and tighten the inner lug which is actually threaded then you put the other wheel over that and the outer lug nut screws to the inner lug nut. one has right had threads the other has left hand. Basically they suck.... and don't even get me started with the in board brake drums vs. outboard drums!!
If I keep this truck any length of time I may look for a set of newer axles out of a wreck or something. Chances are I'll just run it a year or a few months and start upgrading slowly. -
Page 1 of 3
