Any place to get information on how to chain down a load, flat bead or equipment. I have a job interview and have not held this kind of job. Im new to flat bead but dont want to look so new. Any books or online information available?
Thanks for your time
Yosam
Chaining down a load question
Discussion in 'Questions From New Drivers' started by Yosam, Nov 13, 2009.
This might help . http://www.fmcsa.dot.gov/rules-regulations/truck/vehicle/cs-policy.htm . But if you don't have experience and get hired you will likely go through a training period .
im6under Thanks this. -
Thanks for the info RickG
I know the rules and regs. What I would like to know is the tricks of the trade, helpfull hints and thing I should look out for.
Yosam -
cvsa.stores.yahoo.net/prcase1.html
Loads of illustrations and whatnot...not as good as seeing a flatbedder in action, but definitely worth $20. -
Big Don and future driver Thank this.
Loaded a combine Friday with 4 other drivers from 4 different companies (TMC, Hunt, Warren, Valley) Each of us used a different method to secure the loads. One driver used j-hooks. One driver removed his hooks from his 3/8 chain and reattached them on the other side of the j-hook bracket. One driver had his chain hooked straight down to a d-ring, around an axle and then pulled foward at the front and rearward at the rear.
I have 6 ft sections of 3/8 chain with a grab hook on one end and machine hooks on the other. I hooked the machine hooks into the j-hook brackets and hooked the ratchet binder to the sides of the lowboy (2 in the front, 2 rear. Then I used four 2ft 3/8 shortchains and hooked the axles.
Strapped down the tires, hung the flags and banners and I was ready to go.
I guess the main trick would be how you run straps through the winch and secure the ends.Yosam Thanks this. -
I am aware & I refuse to get it. -
Just keep the chains TIGHT - I saw a wide load get pulled in for inspection yesterday (I was inside the coop):" I think he is too wide" "His tag axles are up" " He may be too high" "Wait, he has a loose chain, bring him in"."
thanks for the help drivers
