Just putting this out there, because I had to learn on my own and got lucky, because I was chicken and did a lot of research before the first time I had to DO it.
1. Make sure you have 3 sets of chains. (That's enough to do all 4 drives and one set of drags on your trailers). This is the REQUIRED minimum to run Montana, Wyoming, Idaho, WA and OR. My understanding is that CO and CA require an additional set (enough to put drag chains on both tandems).
2. Watch this video.
3. PRACTICE someplace where it's not -20 and there's no snow on the ground. do it TWICE if there's any confusion.
4. HAVE BUNGIES. I use Octopus bungees, which are about $60 a set. But you NEED 2 bungees per tire. Run standard bungees in an X-pattern so your chains are nice and tight.
5. MAX speed with chains is 30-35 mph. period.
6. KNOW it's a nasty, wet, cold, crappy job. It's just what you gotta do sometimes.
I work for a company who is perfectly happy with me pulling over rather than chaining. Sometimes I do that, sometimes it's Snoqualamie pass and it's a one-time thing and screw it, I chain. But I HAVE chained more for MUD, than I have for snow. And if you work for a company which will be "displeased" with you over having to pay $800 fort a wrecker because you pulled into a mud-pit, knowing how to at least chain the drives could save your job.
Hope that all helps.
Chaining for new drivers
Discussion in 'Questions From New Drivers' started by Jubal3, Feb 11, 2017.
Could have used that 30-35mph max advice last week
Lepton1 and TequilaSunrise Thank this. -
Lepton1, RedRover, Indignant trucker and 1 other person Thank this.
Drop. The. Trailer.
Holy #### why didn't I think of that lolgillz107 and BUMBACLADWAR Thank this. -
I've got a quick question? What length bungee s do you need? I've seen those orange spider things but they are a bit pricey.
Ummmm yeah. Dropping trailers on Snowpack, your going to have a bad day. IMO, I threw 3 railers on a drive axle and your usually good to go. Pro tip: Throw the Iron before your to far into the mud/snow. That way you won't have it falling on top of you from the bottom of the trailer. Good clothes and practice makes it just part of the job.
Ryan423 Thanks this. -
WA requires enough chains for 7 tires for a 5 axle truck and trailer. That is 3 1/2 sets of chains.
I don't use bungees at all. Complete waste of time. Bungees only make a bad chain job look good when the truck is standing still; they do nothing when the truck is moving. Make sure the chains are tight in the first place and don't waste time on rubber crap to overcompensate for bad workmanship. -
IMHO It should be part of the CDL road test for KNOWING how to put them on. Again, just my opinion. Doesn't mean you have to use them but just the knowledge of how to.
