Chains
Discussion in 'Flatbed Trucking Forum' started by EdwinTheGreat218, Aug 23, 2017.
  1. EdwinTheGreat218
    EdwinTheGreat218 Bobtail Member
    47
    23
    Jul 31, 2017
    Chicago
    Getting ready to make that jump to flatbed specialized and was wondering is there any point that it becomes necessary to use more that grade 70 chains. Like if you get into extremely heavy loads, would you have to jump to 80, 100, or 120? Maybe I'm just asking to ask, or maybe I'll never come across a situation where it'll matter, but inquiring minds would like to know.
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Depends on what you haul and what you haul it on. I have grade 100 chains, but only because that is what the company bought. It is useless to have chains rated for 8800 pounds if they are hooked to a pocket only rated for 5000 pounds.
    MarkH129, Tb0n3, Dave_in_AZ and 6 others Thank this.
  4. EdwinTheGreat218
    47
    23
    Jul 31, 2017
    Chicago
    That makes sense, thank you
    Razororange and MJ1657 Thank this.
  5. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    It goes by the lowest rated component. If you have a 4000# chain with a 6000# binder hooked to a 5000# spool you are only going to get credit for the chain.
  6. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Unless you are pulling oversize, you likely will never need more than 1/2" grade 70 chains. Most attachment points on trailers aren't rated higher than about 6,600 lbs WLL.
    Robert85006 and EdwinTheGreat218 Thank this.
  7. MACK E-6
    49,800
    235,699
    A higher grade may be a lot less likely to stretch and break.
    EdwinTheGreat218 Thanks this.
  8. Rontonio
    Rontonio Road Train Member
    6,442
    47,421
    Aug 9, 2009
    I regularly load pieces in 100-120k range and use grade 70 1/2" chain exclusively.
    It might sound like a great idea to reduce the required number of chains in use, but in my opinion it isn't. I want to tie the darn thing down so it doesn't move and generally that takes multiple chains attached in multiple places pulling in multiple directions.
    However, if I could just get one really big chain over the top....maybe anchor chain from an aircraft carrier...
  9. Dye Guardian
    Dye Guardian Road Train Member
    1,329
    12,583
    Jan 10, 2015
    North
    SAR, MACK E-6, skellr and 3 others Thank this.
  10. Gobble Gobble
    Gobble Gobble Bobtail Member
    13
    57
    Aug 23, 2017
    Just lay it over. That'll be good enough.
  11. EdwinTheGreat218
    47
    23
    Jul 31, 2017
    Chicago
    Lol not looking to use just one chain, but for safety sake I've been of those "if it's worth doing, it's worth overdoing" people. I'm not looking to use any fewer chains, just the thought of the same number of chains that I'd use with 70's but with higher rated chains. But maybe overdoing it is just overdoing it sometimes.
