Change Rear gears?
Discussion in 'Ask An Owner Operator' started by 7mouths2feed, Jun 22, 2008.
  1. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    In the interest of fuel milage has anyone done a ring and pinion swap in a commercial truck? I have done several in pick-ups. How much difference is there besides having 2 rear-ends to change? Would it be better to swap the whole rear-end from a cut-off?
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    they are easy to change, just not cheap. they are basically like a ford 9 inch where the whole assembly bolts in. You can buy a remaned unit which comes assembled. you just pull out the axles shafts and replace the center chunk, put nee bearings as needed, new seals and button it up.
    I think a remaned member runs in the $1500 area.
  4. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    Like the other poster said its really like a 9 inch ford and you don't even have to pull the wheels just slide the axles out and swap away. The big thing is the cost versus savings. How long you plan on keeping it and how far you raise it up depends on where you start and the rest of the drive train. You need to stay in the sweet spot of what ever combo you have and still leave some to pull a hill if your running in the areas that you will be pulling long grades and stuff and carrying heavy loads you need to consider how much pulling power you will loose in the mountains. I have a friend that pulls nothing put empty trailers most of the time. He set his truck up with like 2.95 or something rears so he was turning like 11 or 1200 at 70 or 75 miles an hour got some where around 8 miles to the gallon most of the time. Then if he did hook a heavy load he just stayed in 1 gear from the top if he had a head wind or a hill to pull only time he get in the big hole was when he was on flat ground with a loaded trailer but M/T like he normally ran he was saving tons and this was 3 or 4 years ago he did that so he saved enough to off set it had he had to pay extra for it but he made the dealer do it to sell the truck. Just have to do the cost analysis's on it. How much it will change and how long it will take you to recoup the cost.
  5. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    Hey Medicine Man. If you've done a front rear end, how does the through shaft to the rear rear come apart and how fun is it to line up?
  6. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I've never done one. Only time I ever had one go out was on the road and I had it done in the shop in Finley OH
