changeing my fuel filters every 2weeks?
Discussion in 'Kenworth Forum' started by TruckerPete1990, Nov 20, 2012.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    so im a company driver but my company keeps telling me its BAD Fuel.. in the last 1month half ive had my fuel filters changed 4TIMES now... its a 2011 t660 cummins. i dont think its bad fuel i think there is somthing else wrong with the truck. it has 362.XXX right now.
  3. fisher guy
    fisher guy Road Train Member
    1,993
    1,060
    Mar 22, 2009
    Ocala Florida
    what do you do (otr, regional) do u fuel same place every time brand wise or station wise give more details. when i was doing regional we used to fuel up at the same 2 fuel stops and i changed filters once a week until finally the company said no more and changed the stops
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I have changed filters as often as every 200 miles, when I first got fuel at the loves bio fuel. went back to my other stop, & filter will last 25,000 miles.
  5. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    I fuel at pilots and the hook I run otr but running east a lot
  6. snowwy
    snowwy Road Train Member
    20,539
    13,275
    Jul 6, 2009
    bad fuel is a very common problem. and even more common if it's bio. and if your fueling at the same place. that's probably your problem.
    i once had a car. back when the carburetor existed. and had paper filter inside the carb. it was getting changed twice per tank full. and i wasn't gassing up at the same station.
  7. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    hmmm this gonna be a hard one to fig out what fuel stop it is. cuz i fuel at dif ones but non are really common for me.
  8. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    If you've had some bio-fuel you've probably got algea in your tanks. Get some "Bio-Medic" at most any truckstop, will kill the algea but the dead algea will plug your filters even worse till its gone.
    Dewey120 Thanks this.
  9. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    In the wintertime i change more times the fuelfilter ,when i do this i go to Speedco here i pay only 22$ and the instalation is free
  10. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Try the biocide. Do you have a Davco 382 or similar unit?
  11. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Get whoever changes your filters to cut one open and see what it clogging them. Black crud may be organic matter from algae and you would need to go the biocide route. Some drivers have had trouble with Cummins engines cooking the return fuel and turning into almost a tar like substance. If that is your problem you need to research a mechanical solution.
