Changing a Cummins ISX Fan Hub
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Koolk, Dec 13, 2011.
  1. Koolk
    Koolk Bobtail Member
    42
    7
    May 19, 2011
    Richmond, BC
    Was just wondering how much work is it to change a fan hub. 2008 KW T800 and Cummins ISX. There is barely enough room to put you hand in there. The Rad is jammed up right on the fan. Their seems to be a noise from the front of the motor. A minor squeek. I removed the belts and it went away. Maybe tensioner or Fan hub. Any input Thanks! Ken
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    I would try a tensioner first if your concern is the squeak noise. Tensioner springs do seize up over time and allow the belt to run a bit loose.
    Koolk Thanks this.
  4. Allow Me.
    10,720
    12,410
    May 28, 2009
    Rancho Mirage, Ca.
    You might have to remove the radiator, not sure.
  5. The Truckist
    The Truckist Medium Load Member
    342
    245
    Sep 11, 2010
    KoolK,
    More than one has slipped and gouged a hole in a radiator trying to get at what you're talking about. Better safe than sorry. A side note...you may be able to loosen/unbolt the top mounts (according to how KW mounts theirs) and loosen the bottom some to allow the radiator to tilt forward enough to work on it. I can do this on my Peterbilts but not sure how KW mounts theirs. The book will say...drain, remove, etc.
    Here's a link to a good parts interchange for heavy duty belts, tensioners from the Gates folks. You can enter your VIN or a part number...try it...you'll like it :)
    http://www.vindecipher.com/gates/
    I agree with try the tensioner first.
    Koolk Thanks this.
  6. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    Be careful. It weighs about 70 pounds. You drop it into the radiator and you will need that to.
  7. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    Our guys usually secure the hub to the overhead crane. An engine hoist might be able to come in from the side and support that lump of iron! Instantly reminded me of putting a bolt head through the rad of my old Falcon when i was trynig to do the fan hub and water pump without pulling the rad. Lesson learned!
  8. Heavyd
    7,804
    6,253
    Feb 4, 2009
    We try to slip in some cardboard in between the rad and fan to help gaurd a little bit against damage.
  9. Koolk
    42
    7
    May 19, 2011
    Richmond, BC
    Thanks guys, I never thought it was that heavy. Gonna get the shop to do it. Tech said they tilt the Rad forward to make room. Plus change all the rad hoses and clamps at that time. Quote 2-3 hrs labour. Sounds fair. Thanks for help.
