changing brake linings
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jakescia, Apr 17, 2009.
  1. jakescia
    jakescia Bobtail Member
    32
    Aug 4, 2008
    Oskaloosa, Iowa
    What kind of mileage are you getting out of short haul tractor brake linings...........and.........are you changing the drums with each change in linings?
    What kind of money are you paying for the drums?
    Thanks.
  3. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    $95.00 for cast drums $207.00for steel drums difference is about 40 lbs between steel and cast,,, steel being lighter is what i was told by Kenworth.
    break shoes and drums Milage i havent a clue, but im sure is depends on your braking habits and how much you use the jake.
  4. Biscuit75
    Biscuit75 Road Train Member
    I never had a short haul tractor, but OTR I used to get 250,000+ miles. So I would assume maybe cut that in half for city type driving. As far as changing drums... I didn't have to do that every time I changed pads. Just check them for wear and cracks when you have them off. I agree with 2hellandback on the prices. If you have a Truck Pro in your area, I always got good prices from them.
  5. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    i usually change drums after the second reline . some guys go more than that but if the drum gets too worn they will explode which can cause extra damage and costs more to repair. i run alot of local new york city stuff i usually get about 100,000 out of a set of shoes some guys alot less depends on your driving habits
  6. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    I do a lot of urban driving loaded heavy. Shoes last about 90,000 miles, every other brake job I put new drums on. Steer axle shoes only last 50-60,000 miles but get 3 brake jobs out of those drums.
  7. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    We are a long narrow volcanic country, big hills (9%+) stop start traffic 100k lbs 90% loaded on 7 axles,trailer axles on 19.5 inch rims,truck 22.5 have done 700,000km if I don't get 1 million kms out of one set of the shoes and drums I will be devastated.
    I do have jakes and a brakesaver screwed up to 60 psi about 800hp engine braking this dose help a lot.
