Changing Gear Ratio From 3.90 to 4.56
Discussion in 'Experienced Truckers' Advice' started by White Line Fever, Jul 13, 2018.
  1. White Line Fever
    White Line Fever Bobtail Member
    46
    22
    Dec 6, 2015
    Hi guys,
    I have a Western Star Tri-Drive with a DD16 and 3.90’s. I’m thinking about changing to something lower like a 4.56 or 4.30 at the least. The truck is spec’d heavy, double frame etc but right now isn’t geared low enough for the weights the truck will be pulling (150 - 200,000 lbs). Presently the truck will go just a hair under 90 m/hr, which is definitely not needed for pulling that I do the jeeps/ wheelers etc need to be going that fast.
    I’m definitely aware of the fuel issue but when you’re pulling these weights the fuel economy is out the window.
    I’m just getting tired of having to cover my headlights so my truck doesn’t see the hill
    I’ve seen similar trucks pulling identical loads with the 4.30’s and it is a huge improvement, yet they are still fairly long legged. I’m more interested in being able to lift off in the soft ground pulling 40 or more wheels than doing 80 miles an hour.
    Has anyone made this change that can offer some good advice?
    Thanks in advance.
    Lepton1 Thanks this.
  3. singlescrewshaker
    4,852
    42,406
    Dec 31, 2017
    Little Havana, FL
    Don't know if this helps you but..
    My little truck has
    -11r22.5
    -4.10 rear
    -.73 overdrive
    It will spin about 1705-1710 @ 70mph..
    White Line Fever and Lepton1 Thank this.
  4. 03machwon
    03machwon Medium Load Member
    305
    425
    Jun 19, 2013
    I don't see the point if you're staying under 200k... I'm usually around 195k...with a DD15 505/1850 with 3.91 gears and 24.5 tires....truck handles any terrain I throw at it just fine.
  5. White Line Fever
    46
    22
    Dec 6, 2015
    I know we’re not supposed to use the D word here. Are u stock and on soft leases? I know when I’m in bull low and let out the clutch...I should be able to move...lol
  6. Espressolane
    17,777
    109,430
    What transmission is in this.
  7. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Get it geared so you are cruising in direct drive gear. Not sure what trans you have? 4.33 or 4.55 sounds about right.
  8. TripleSix
    130,836
    A 3 speed auxilliary transmisson on the back of your transmission or switch to 3.90s with 2 speed rears.
    White Line Fever Thanks this.
  9. White Line Fever
    46
    22
    Dec 6, 2015
    I have thought briefly about the 2 speed tears but haven’t actually looked into it. I’m thinking I should...be nice to know what’s out there.
  10. TripleSix
    130,836
    With a specialty rig, you're going to have high deadhead...possibly50 percent. Your 3.90s and two speed rears would hive you much better performance and overall economy, loaded or empty.
    Oldironfan Thanks this.
