Changing Hubs From Grease To Oil Bath
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Juicehauler, Apr 9, 2014.
  1. Juicehauler
    Juicehauler Light Load Member
    59
    18
    Dec 17, 2013
    Another question about my Pete for you guys, the truck has a Meritor front axle with sealed, greased bearings, ive heard of these causing issues in the cold winter months up here so im think of changing the bearings and caps so i can just use oil instead. Does anyone know if i can use the same bearings, or are they different for oil bath?
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Your axle is probably a Meritor FF981 with unitized wheel ends. The spindles are unique to this axle model and so are the bearings. The bearings are a maintenance free sealed type that cannot be swapped out for regular bearings. Generally these are good axles/hubs. The bearings do fail around 1 million miles. I haven't seen anyone just replace bearings. We normally replace the whole hub complete with new bearings when there was a bearing failure. We have also replaced the odd complete hub for preventative measures, but not too often.
    Juicehauler Thanks this.
  4. Juicehauler
    59
    18
    Dec 17, 2013
    That's nice to know, the truck has 1.4 mill on it, hopefully they have been done in the past, I'm not having any irregular tire wear and it just passed safety, so I guess they are in good shape, so far...
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    I would leave them be till they ware out . Seal has a much easier time keeping the grease in then oil .
  6. RideOnTransport
    RideOnTransport Bobtail Member
    I also have a unitized hub KIT-1478 for axle FF-986 and think it is a joke. Designed to ease assembly at the manufacture, but expensive for the consumer quoted $1,000 for hub assembly not including labor by local shop at the cheapest. I would assume there is a way to replace the bearings yourself, but have never heard of anyone trying. I would like to change to something I can maintain myself without getting rear ended by the industry!
  7. jking006
    jking006 Bobtail Member
    46
    14
    Jun 23, 2013
    cadiz, ohio
    I also have the sealed bearing on the front of my international. . At 914,000 the left one failed.. shop quote was over a grand for one hub assembly. I got it replaced I guess the upside was less than an hour in labor... The only way to convert to oil bath is to swap out the front axle. . I'm considering that on my truck.. I can buy a used axle and replace the oil bath bearings on it with labor and still have just a little over a grand in it
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I had old volvo cabover with oil bath bearings, now I have 2001 volvo with grease hubs and freightliner with oil bath hubs.... really cant see any big difference as for owner, so I'd keep all as is
  9. jking006
    46
    14
    Jun 23, 2013
    cadiz, ohio
    The difference is the sticker shock you get when your told the price of that spindle over a grand a piece and also your stuck at a shop that may not be able to get it for a couple of days. . So now your lost revenue makes it worse... oil bath bearings I think the last ones I had done was like 350 with labor and most ships can have those same day if they don't stock them and your back on the road in a couple hours.
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    agree, this is argument
  11. Stone Express
    Stone Express Medium Load Member
    342
    468
    Feb 26, 2013
    I was always interested in the difference in rolling resistance between the two. Would seem the oil feed bearings have less drag and therefore run cooler......also, the oil should dissipate heat quicker than grease, but maybe not...
