Changing the rear end of t600
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bucktrucker, Jun 19, 2011.
  1. Bucktrucker
    Bucktrucker Medium Load Member
    453
    148
    Dec 10, 2008
    ON THE ROAD SOMEWHERE
    I just bought a 07 t 600 but it has 325 rears and they sux but i new they would but i got such a good deal on the truck i just couldn't turn it down. So i going to change them. Now does anyone have any idea what thats going to cost me ? And will i have to change the peremeters in the tranni. I pull alot of 45,000 pound loads and this just ain't cutting it. I thought about going to 355s im not a speed deamon but i just want it to pull good. I have a 475 cat with a ten speed any advise ?
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    what is it that you dont like about the 325's--should be good rearends for fuel mileage
    all i have ever driven is mainly 370's
    was kinda wondering if maybe a 13 speed would work better with a high geared rear end like you have
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    If the 10 spd is a direct not an OD then you really need to keep them 325's just to keep your rpm's lower.
    Bucktrucker Thanks this.
  5. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    thats why i was kinda thinking a 13--with those rears it take awhile to get up and running at speed wouldnt it? and the split would keep your rpms up so you wouldnt have a big drop at shift point which would seem worse with a high rear end
    or maybe i just havnt had enough coffee yet
  6. Bucktrucker
    453
    148
    Dec 10, 2008
    Well thats why im asking. Im running about 1325 at 68 mph. The big things is the drop in rpms from 9th to tenth. This really kills me. If i shift out of 9th at 15 hundred to 10 it falls in at 10.5 rpms and on a hill it just want pull it out. I would prefer a 13 anyday over a ten and if thats what i need to change i will i just want it to pull good and still get good fuel mileage. thanks guys
  7. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    Swapping trannys aint the answer. A 13 speed has the same top gear ratio and actually has a higher low hole than a 10 speed. Im sure even with 3.25s its a 10 over. The whole gear it high run it slow for fuel economy thing is BS! With my current truck running anything under 64 mph it gets better fuel milage half a gear down. If you lug em they burn fuel. You need to keep em in their free running range. Usually a few hundred RPMs above peek torque. Your C-15 cat makes peak tq at around 1250 Rpms. If you run it a 1450 it will pull better and get better fuel economy. Go with the 3.55s if you have low pro 22.5s. if your tires are bigger than that then I would want even lower. Price wise $3500 for the front rear and $2500 for the rear rear. Just a bll park figure.
  8. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    i think it is the rpm drop that he doesnt like and a 13 would get rid of that- idont mind tens on the flat--and light--but when get heavy and in the rocks--they are a bit miserable and sometimes the only way to keep the truck in its happy spot is to be able to split a gear
  9. dwmac71
    dwmac71 Light Load Member
    183
    92
    Mar 23, 2008
    Lane,ks
    I have been talking with Inland Truck Parts in kansas city mo about re-gear my truck from 3.55 to 2.64.
    They quoted 1800.00 front, 1200.00 rear re geared and rebuilt if i brought them in.
    3.55 use a different ring gear carrier than 2.64s which pushed the cost up.
    The carriers split 3.25 and up so you can go 3.55,3.70 or 3.90 with out much problems.
    I've been quoted 12 shop hours for R/R here in the kansas city area.
  10. Bucktrucker
    453
    148
    Dec 10, 2008
    Thanks thats what i thought as well just to high for the mountians. I have a friend that has a t600 same c-15 with 355 he always gets better fuel than me he also has a 13 though, And it will pull away on the hills .Thanks for the response guys.
  11. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    I know this is a old thread but if you still want 3.55's I'll trade you even up and split the labor 50/50.
