Changing transmission from 10 speed to 13 speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by caribou8820, Mar 21, 2020.
  1. caribou8820
    caribou8820 Bobtail Member
    15
    8
    Jan 21, 2014
    Hey everyone. Thanks for the info in the previous post about the Detroit 12.7, good advice.
    This truck has the Eaton Fuller 10 speed, would like to switch to 13 speed at some point; hopefully in a few months. Any idea of a ballpark figure on cost on this? Thinking of getting a 13 speed core that I could exchange with Microblue for one of their rebuilt transmissions. I know I have to get the driveshaft shortened. Any other issues to look for in this process. The truck has somewhere in the ball park of 1.1 million miles, at least that is what the engine ECM is reading; have no way of knowing if the engine has been changed or not. The speedo has been replaced so I can't go by that; thinking if may have more miles; so anyway the transmission is kind of sloppy in shifting so it seems to have some wear.
    Would also like to put in a clutch with an EZ push pedal of some sort, the one that is in there is a killer; never run across one so hard to push in.
    In recap need advice on switching to 13 speed on a 1999 T600 with a 10 speed currently, 12.7 Detroit. 3.55 rears. Thanks. By the way I did get into this truck fairly cheap so I have a little to work with; in case you're wondering.
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    What is the model number on the tag of your transmision.
  5. caribou8820
    15
    8
    Jan 21, 2014
    FRO15210CP. It's a 1550 foot pound transmission, which makes me wonder why the clutch is so heavy. Wouldn't think it would be that heavy of a clutch in front of that transmission. Kind of wondering if there is something wrong with the clutch or it's out of adjustment in some way. I have it at my local repair shop right now and they are going to look at it; but haven't gotten to it yet. They just finished the notorious Detroit diamond seal oil leak on Friday; so may get to that on Monday.
  6. caribou8820
    15
    8
    Jan 21, 2014
    Driving a 579 Pete with the 13 speed so that's got me a little spoiled; the clutch is like pushing in the clutch on a Honda Civic or something. But my previous truck was a 2006 T600 with the ISX and the RTO16913; don't remember the clutch on that being anywhere near this hard either. Could be that I'm a little soft as I'm been out of trucking for a couple years!
  7. BoxCarKidd
    4,517
    6,576
    Aug 26, 2014
    If the pedal is that hard to push the clutch is probably bad.
    On Fuller Transmission ratios - Fuller . Com. A Fro15210C is 0.74 OD. I find no RTO16913 but some other models have similar OD ratios. Just look at what your are putting in. You would not normally want to lose 10%.
  8. jamespmack
    216,319
    Dont waist your money on micro blu. I worked on a guys truck that we tried wheel bearings and 2 diffs. ZERO gain noticed.
    I just installed what the owner wanted. What a waist of money.
    BoxCarKidd Thanks this.
  9. Green461
    Green461 Light Load Member
    154
    106
    Mar 22, 2019
    Southern WI
    I found a grease fitting on my clutch linkage, greased it and wow... its so smooth and easy now. Also sprayed a little lube on all the linkage rod ends. day/night difference over all.
